Thread: 02 3800 series cold air intake help plzzz
Results 1 to 2 of 2
jward2155 02 3800 series cold air... 07-21-2012, 07:58 PM
Fivefingerdeathpunch Re: 02 3800 series cold air... 07-21-2012, 07:59 PM
  1. #1 02 3800 series cold air intake help plzzz
    Jul 2012
    Indiana
    so im trying to install a new cold air intake and i take out my air filter housing and attached to the bottom portion of the filter is a box with wires im thinking its the pcm maybe??? but im not sure what to do with it i could maybe strap it to the frame but im not sure if its supposed to be in that box to keep it from being damaged by the heat in the engine compartment any info that would help me would be greatly appreciated thanks
  2. #2 Re: 02 3800 series cold air intake help plzzz
    Correct its the PCM.
    Its weather proof and for the most part shock proof, just take it out and lay it there, zip tie it down if you want to.
  1. Will a series 1 3800 tranny fit a series 2
    By 2002grandprixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2012, 01:06 AM
  2. 3.8 series III mods! HV3 and cold ar intake advice?
    By tomasz26 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2012, 08:12 AM
  3. Series III 3800 intake and exhaust tips?
    By 2004GrandPrixGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2012, 07:42 PM
  4. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
