Thread: Another overheating post..
Results 1 to 16 of 16
  1. #1 Another overheating post..
    SE Level Member MyPrixGT06's Avatar
    Weirton, WV
    I started to overheat and changed The coolant elbows then later needed to change the lower intake gasket. It was running great for a couple weeks and now it's getting warm again. I am loosing coolant. I have to add a splash every other day. When it's really warm I can hear a hissing from left side. I can't tell if it's by the belts and elbows or closer to the front by the lower rad hose. I can't see a leak anywhere. COuld removing the elbows to change the lower intake have broken the new elbows? I did oil then before installing both times. Plz help thanks
    2006 Pontiac Grand Prix GT-
    180 tstat and intake.
  2. #2 Re: Another overheating post..
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    The elbows almost always break or crack when doing a LIM gasket job. Although being yours was new it might not have... I'd deffinantly take a good look at it and see if you can see coolant coming from there
  3. #3 Re: Another overheating post..
    if you can hear a hiss, i'd start with rechecking the elbows. did you clean the holes real good? where the elbows go, both sides, the bracket as well?
  4. #4 Re: Another overheating post..
    Weirton, WV
    Clean the hoses that come out the back of the braket? I cleaned out the old elbows that broke inside the block and bracket. I might take it off tomorrow and check...
  5. #5 Re: Another overheating post..
    Sep 2011
    MI
    Anything loud enough to hear a hiss is big enough to leave a puddle. Could be your A/C if you hear the hiss with the car off.
    I assume you bled the system?
  6. #6 Re: Another overheating post..
    Weirton, WV
    Quote Originally Posted by 99PontiacGTP View Post
    I did bleed it after every opening of the system. The a/c unit is around there but I do t think I've ever hear this noise before.
  7. #7 Re: Another overheating post..
    Weirton, WV
    I replaced the gasket between the supercharger and manifold. The coolant portion had damage. After refilling coolant im still having to add a splash every other day and don't see a leak anywhere. Also if it needs coolant isn't it suppose to take from the reserve tank? Mine never has. Tank will be at full line and radiator empty... (while I was at it I clean the crap out of the supercharger and manifold and it's amazing!!!!)
  8. #8 Re: Another overheating post..
    Mar 2012
    NC
    Quote Originally Posted by MyPrixGT06 View Post
    Have you pressure tested the radiator cap or replaced it? Without pressure in the system, the coolant will be able to evaporate since pressure in the system increases the boiling point. Also, a faulty radiator cap will make it so the cooling system never pulls from the overflow reservoir. Just a thought.
  9. #9 Re: Another overheating post..
    Weirton, WV
    Quote Originally Posted by hitman92499 View Post
    Interesting! I didn't think of that. That will be the next thing I try. Do shops charge to pressure test?
    What part of the blower did you clean?
  11. #11 Re: Another overheating post..
    Weirton, WV
    I used brake cleaner on the throttle body, supercharger, and manifold. I was very gummed up.
  12. #12 Re: Another overheating post..
    Mar 2012
    NC
    If you can't do it on your own, just replace it for good measure. If it fixes it then you win!
    Im curious about the supercharger rotors and if their coating is still intact.
    Also apparently gm had some issues with rad caps failing which aggravated dexcool to sludge. Didnt keep the cooling system full.
  14. #14 Re: Another overheating post..
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    If the reservoir tank is full and the rad is empty, either the cap is bad or the hose has some type of blockage or pinched. If you remove the cap, can you see coolant flowing from the tube into the rad?
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  15. #15 Re: Another overheating post..
    Weirton, WV
    Quote Originally Posted by 99XC600 View Post
    It flows through that hose. Wow if I've taken my car apart 3 times and it's the dang radiator cap I'll be pissed! Well not really. At least I got to clean it out and change gaskets that if weren't broken b4 would eventually break. I'm gonna get a cap on break.
  16. #16 Re: Another overheating post..
    Apr 2012
    Wilbraham MA
    Just remember that the radiator cap is essentially another thermostat that is set to open at a certain PSI. If it doesn't open, the coolant won't have a place to expand when it's at operating temp.
    Too see how it work's just put it on the bench and fill it with some water. Push the plunger down and the passages will be exposed and the water should flow out. This is how the coolant from the overflow tank flows into the rad.
  1. Car overheating
    By Wsmccoy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2012, 07:48 PM
  2. 3.1 overheating
    By kenjr in forum General Grand Prix Discussion
    Last Post: 05-03-2012, 01:55 PM
  3. overheating
    By pvtgearhead1210 in forum General Tech Discussion
    Last Post: 11-09-2011, 06:03 PM
  4. car overheating
    By darkfox1009 in forum General Tech Discussion
    Last Post: 06-20-2011, 09:23 AM
  5. Overheating?
    By Dr.Sherman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2011, 07:12 PM
