Thread: AC Issues, Any Suggestions...
Results 1 to 5 of 5
  1. #1 AC Issues, Any Suggestions...
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    I know, I know, it is hot everywhere but come on, I cant go without cold air, lol....The issue that I am having is that the AC coming out of the drivers side vents isn't nearly as cold as the air coming out of the passenger side. It is not hot air but not nearly as cold as the passenger side. My car is a 2000 GTP w/ Duel Climate Control...Any suggestions would be grateful. Thanks
    2000 Grand Prix GTP
  2. #2 Re: AC Issues, Any Suggestions...
    Could be the blend door actuator or you might be low on R-134a
  3. #3 Re: AC Issues, Any Suggestions...
    I'd check into the blend door first.
  4. #4 Re: AC Issues, Any Suggestions...
    Shelbyville, IL
    Okay, what is the easiest way to check the Blend Door? Thanks in advance...
    2000 Grand Prix GTP
  5. #5 Re: AC Issues, Any Suggestions...
    http://www.grandprixforums.net/blend...ent-21941.html
    once you have it off you can turn the little knob by hand and see if you get cold air. if not your low on R-134a
  1. suggestions
    By RyanL in forum Forum Bugs/Suggestions
    Last Post: 03-18-2012, 09:29 PM
  2. Suggestions
    By tyv193 in forum Brakes/Suspension/Chassis
    Last Post: 12-10-2011, 01:03 PM
  3. Suggestions please?
    By Shedd22 in forum Visual/Body Modifications
    Last Post: 06-09-2011, 08:52 PM
  4. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  5. Suggestions Needed: L32 cylinder head issues
    By Angelo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2009, 06:55 PM
