Thread: ABS Light staying on
Results 1 to 8 of 8
  1. #1 ABS Light staying on
    Jul 2012
    Omaha, Ne.
    I recently bought a 98 GP and a few weeks after owning the car the ABS light came on and now wont go off. Any suggenstions on how to fix this?? Any help would be greatly appreciated.
  2. #2 Traction Control System
    Jul 2012
    Omaha, Ne.
    I recently bought a 98 GP and have noticed that by pushing the TCS button it wont turn on. Any suggestions on how to fix this problem?? Any help would be greatly appreciated.
  3. #3 Re: Traction Control System
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    one of ya wheel hubs.. i seen ya other post about abs.. both are same problem.. check ya hub wiring..
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: Traction Control System
    I live here. TLSheff's Avatar
    Quote Originally Posted by 98IndyGP View Post
    You mean off? By default the TCS is on.
    And ya, check the hubs
  5. #5 Re: ABS Light staying on
    to go with http://www.grandprixforums.net/tract...tem-65708.html
    Check the wheel hubs, tend to be the main cause.
  6. #6 Re: ABS Light staying on
    no need for 2 threads.
    merged
  7. #7 Re: ABS Light staying on
    SE Level Member wavedout33's Avatar
    Jul 2012
    oklahoma
    i have a hunch that the front passenger hub wires are either loose, dirty connections or ripped out of the plug...I have the same issue but I'm not worried ima buy a hub soon lol
  8. #8 Re: ABS Light staying on
    St. Louis
    FYI to the OP, your ABS will not be working with that light on, so if you get into a situation that requires you to stomp the brakes you WILL lock them up. At least on my 00 GT that's what it does, lol..
  1. How much power can I make while staying N/A?
    By GrandprixGT01 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-20-2012, 09:52 PM
  2. JCovington and my new 2005 gtp (staying stock)
    By jcovington in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:13 PM
  3. HELP!!! DRL's Staying On
    By kodeblue in forum General Tech Discussion
    Last Post: 01-21-2012, 02:53 AM
  4. wipers staying up
    By Jakegday in forum General Tech Discussion
    Last Post: 12-15-2009, 03:35 PM
  5. abs and trac off light staying on
    By gtpinsc in forum General Tech Discussion
    Last Post: 08-20-2008, 07:34 AM
