Thread: Engine overheating/ Need Help
Results 1 to 19 of 19
  1. #1 Engine overheating/ Need Help
    Illinois
    2004 Pontiac GT 3800 Series 3.
    Recently, the power steering pulley fell off, thus the belt, which caused the engine to overheat. Everything got put back together, but now the car's been losing coolant and overheating again. After taking it for a drive and temp. needle nearing the red zone, pulled in the driveway and noticed a hissing sound. Found the hissing coming from a plastic elbow out of the block and into a passage between the water pump and tensioner. How do you replace this elbow? Does it just push into the block and into the passage under the tensioner, screw in or what? Do I need to remove anything to change this? Are there any other elbows I should be looking at, and if so, where are they located? Water pump does not appear to be leaking, so I'm thinking this may be my only problem. There is enough coolant in the system right now, and though I'm losing it, it's not losing a lot but still overheating the engine. Thanks for any help.
  2. #2 Re: Engine overheating/ Need Help
    yeah, sounds like you need new coolant elbows.
    You just have to remove the alternator, then unbolt the alt bracket/tensioner bracket, the coolant flows through them.
    After you get it loose, wiggle both coolant elbows out (one front and one on the back), clean the area and install the new ones.
    After you are done, you need to bleed the cooling system of air with the bleeder on top of the thermostat housing. The air causes the overheating.
  3. #3 Re: Engine overheating/ Need Help
    Jul 2012
    Grand rapids
    It is called a coolant elbow they are made of a weak plastic fiber from gm the ones that are aftermarket naps ext. are a good rigid plastic.They are a common problem on these 3.8 there is another one behind the heater core block. It is not that hard if you know how to do them and yes they just push in. If and when you do it its pretty much doing a lower intake job take job and remember to do both elbows never have to worry about them again.
  4. #4 Re: Engine overheating/ Need Help
    Illinois
    Thanks for the valuable information. I'll let you know how it went.
    Do you recommend I drain all the coolant, or just let what comes out, come out?
  5. #5 Re: Engine overheating/ Need Help
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    I'd drain the coolant to save what you can to put back in and be less of a mess. But just my opinion.
  6. #6 Re: Engine overheating/ Need Help
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Drain and flush.
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
  7. #7 Re: Engine overheating/ Need Help
    Illinois
    I think you're right. Thanks.
  8. #8 Re: Engine overheating/ Need Help
    Illinois
    Are these coolant elbows also referred to as "heater hose connectors"? The only thing I found was on NAPA's sight that looked like these fittings. The p/n is 6601943. If anyone knows if this is the right part, would you let me know? Thanks.
  9. #9 Re: Engine overheating/ Need Help
    i dont think you'll see em online
    buy they are found in the store
  10. #10 Re: Engine overheating/ Need Help
    Jan 2012
    Indianapolis
    24503423 Upper coolant elbow GM Part#
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    When you put the new elbows in place its wise to place a bead of black rtv in front of the orings. Peace of mind is nice too, theyll seal up great that way.
    Sent from my PC36100 using Tapatalk 2
  12. #12 Re: Engine overheating/ Need Help
    Illinois
    Thanks again for all this advice and info.
  13. #13 Re: Engine overheating/ Need Help
    Illinois
    Update: Job went smooth. Used scotch brite inside openings and cleaned up with acetone. Did this because ends of fittings all stayed inside the ports. Took a little while to get two of them out, but not bad. Smeared black rtv in front of o-rings, kind of wish I would have left the bead instead of smearing it, but hopefully it'll be alright. Decided to wait till tomorrow morning to refill with coolant, giving rtv time to cure. Don't know if it makes any difference or not. Will update again tomorrow. Any opinions on what I've done so far is sure welcome.
  14. #14 Re: Engine overheating/ Need Help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    the one coolent elbow is easy to find (the one below the s/c snout) where is the other one though? i have no clue where the heater core is also
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  15. #15 Re: Engine overheating/ Need Help
    The two tensioners on the right have both elbows in them. turn your head sideways and it'll make more sense.
  16. #16 Re: Engine overheating/ Need Help
    Oct 2011
    Michigan
    alright that makes a lot of sense now, i just went out there to look at it how to i replace the bottom one with doing a full LIM job all i want to do it both the coolent elbows
  17. #17 Re: Engine overheating/ Need Help
  18. #18 Re: Engine overheating/ Need Help
    Oct 2011
    Michigan
    you have a write up for everything dont you bill?
  19. #19 Re: Engine overheating/ Need Help
    Illinois
    Refilled cooling system, drove car until up to operating temperature then bled air from system. Everything looks ok. Thanks to all of you who guided me through this. Very appreciated.
    One question. The temperature needle goes up to 1 mark before the 1/2 mark on the gauge. Does anyone know if this is where it should be? Just curious.
  1. Engine overheating?
    By mick777wauchope in forum General Tech Discussion
    Last Post: 04-19-2012, 12:14 PM
  2. engine overheating.
    By BlackGT97 in forum General Tech Discussion
    Last Post: 10-09-2011, 11:09 PM
  3. p0304 code and engine overheating!!!!!!!
    By sinister1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2011, 12:55 PM
  4. overheating
    By mcdriver in forum General Tech Discussion
    Last Post: 01-24-2011, 01:24 PM
  5. Engine keeps overheating
    By bigpapa53023 in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-30-2009, 07:05 PM
