Thread: Engine overheating?
Results 1 to 17 of 17
  1. #1 Engine overheating?
    Apr 2012
    Wyoming, MI
    My 2000 Grand Prix GTP has been getting alot hotter than it normally does. Usually it stays between 160 and the first line above that for the engine temp. But now its starting to get just below 210. It NEVER gets that high, and I am not even driving it that hard.
  2. #2 Re: Engine overheating?
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    coolant elbows? last time it was flushed ? it have dexcool or green stuff? im dealing with these issues, and put almost everything new in...maybe its the lim gaskets?
  3. #3 Re: Engine overheating?
    GTX Level Member blackflag's Avatar
    Virginia
    My temp reading on my dash is about the same, also my scan gauge reads about 15* lower than the dash does. As far as I know, your within normal stock temps.
  4. #4 Re: Engine overheating?
    Virginia
    stock tstat?
  5. #5 Re: Engine overheating?
    Apr 2012
    Wyoming, MI
    180* thermostat
  6. #6 Re: Engine overheating?
    Virginia
    I see... That changes things.
  7. #7 Re: Engine overheating?
    Apr 2012
    Wyoming, MI
    Shouldn't that just make the radiator fans kick on 15* cooler than stock?
  8. #8 Re: Engine overheating?
    Virginia
    right, keeping it cooler. I was originally telling you that it was normal for a stock car that is all.
  9. #9 Re: Engine overheating?
    Nov 2011
    Virginia
    Check your coolant level and bleed the air out. Check your water pump. Feel underneath it for wetness. Also look right below the SC snout to see if there is some coolant build up there, if it is then it is the plastic elbow connecting the alternator bracket to the intake.
  10. #10 Re: Engine overheating?
    Apr 2012
    Wyoming, MI
    Quote Originally Posted by CDooley View Post
    My coolant level is fine, but there is gunk in the radiator cap. How do you bleed the air out?
  11. #11 Re: Engine overheating?
    Quote Originally Posted by mick777wauchope View Post
    Quote Originally Posted by BlackFlag View Post
    Wrong and wrong.
    The 180 thermostat will only keep temps cooler while driving. The fans will not come any sooner than before. Stock fan settings are 214 and 228 IIRC.
    If you had your PCM tuned/flashed then those setting could be changed, but for you everything is still the same and it will still heat soak fast in traffic because the fans have not been changed.
    But like others have said, you could try a coolant flush and bleed the air out for peace of mind.
  12. #12 Re: Engine overheating?
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    Gunk in the cap = LIM gaskets most likely bad. Time to change them.
    4 out of 3 people have trouble with fractions
  13. #13 Re: Engine overheating?
    Virginia
    Wrong and wrong.
    Why wouldnt we be talking about temps while driving. He didnt say idle temps.
  14. #14 Re: Engine overheating?
    No comment.
    Because I dont care.
  15. #15 Re: Engine overheating?
    Apr 2012
    Wyoming, MI
    When I idle, my temp would go way up, but when I drive, it stays lower.
  16. #16 Re: Engine overheating?
    Nov 2011
    Virginia
    Yea try flushing the cooling system. It's pretty easy to do. I can't think of what the stuff is called but buy a bottle of radiator flush or cooling system flush and just follow the directions on the bottle. And yea you are going to need to replace the upper and lower intake manifold gaskets if you havent already, they commonly fail. There is a good how to on this forum with a video if your handy with tools.
  17. #17 Re: Engine overheating?
    Virginia
    Nm my avg temp is 185. I also did a little reding up on tstat function, I see the error in my ways. Good call five.
  1. 97 gtp overheating -_- help?
    By Leiliel666 in forum General Grand Prix Discussion
    Last Post: 03-15-2012, 03:15 PM
  2. engine overheating.
    By BlackGT97 in forum General Tech Discussion
    Last Post: 10-09-2011, 11:09 PM
  3. p0304 code and engine overheating!!!!!!!
    By sinister1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2011, 12:55 PM
  4. Engine keeps overheating
    By bigpapa53023 in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-30-2009, 07:05 PM
  5. overheating
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2008, 10:18 PM
