Thread: p0304 code and engine overheating!!!!!!!
Results 1 to 20 of 24
  1. #1 p0304 code and engine overheating!!!!!!!
    Asheville nc
    Ok guys here is my question I have a 2001 gtp with 93,000 miles on her. I have changed the plugs, wires and the #4 injector switched coils to try and nail down what is causing this code? Not to mention the over heating issue i have flushed the radiator and changed the thermostat. i have inspected the vaccum lines as well can't find a problem there. So what am i missing? oh yeah plus the fuel filter has been changed. im running a K&N air filter and autolite 606 plugs. with autolite 7mm plug wires. Any help would be great.
  2. #2 Re: p0304 code and engine overheating!!!!!!!
    Western New York
    loosing coolant? are electric fans kicking on high speed ?, do you have bubbles in radiator ?
  3. #3 Re: p0304 code and engine overheating!!!!!!!
    Asheville nc
    I'm not loosing coolant that im aware of . Fans are starting in low speed then stepping up to high. I havent seen any bubbles except in the coolant res. Its over heating but never making it into the red the fans kick on around 210. It does however rise above that even when driving unless you are running around 70 then stays well below 210.
  4. #4 Re: p0304 code and engine overheating!!!!!!!
    Western New York
    Have you Burped the system after your coolant flush? Air bubble maybe stuck behind thermostat... check around vibration dampner for moisture/coolant , i have the same car in the garage and also found usage of very small amount of coolant (not enough to worry about) over a weeks time.. but will overheat when idling
    i found the alternator bracket is also a coolant housing for the heater core hoses.. this housing plugs into the block(center of motor,a plastic 90*tube under blower pulley) and into housing that water pump is attached to. it may look like this--
  5. #5 Re: p0304 code and engine overheating!!!!!!!
    Asheville nc
    I have not burbed the system. What is the procedure for burbing the system? Also should I run a cooler thermo?
  6. #6 Re: p0304 code and engine overheating!!!!!!!
    on the thermostat housing there is a brass screw, warm up the engine and open the screw a few turns, when bubbles stop coming out and you get a steady stream of coolant shut the screw. top of the radiator.
  7. #7 Re: p0304 code and engine overheating!!!!!!!
    SE Level Member fst4dr's Avatar
    Calgary
    you should really leave the rad open and just run the car till the fans turn on then top up the rad and that should have the air all out of it. as for the missfire..... have you checked the connector for the injector? if the pins are not making good contact it will cause a missfire condition. I had this on cyl #3 when I first got my car, took a bit to find it but finally found that the ground terminal was just not making a good connection. used a small pick and bent the tabs back down so they would press tighter on the pins of the injector and BAMM! problem solved!
    1998 4dr GTP Bright Red
    180* Stat/FWI/ZZP PCM/SD Headers/MPS 3.4/104's/6000k H.I.D/Tinted tails/Eibach's/GMPP STB/12'' Brake upgrade/18'' Ruff Black/Machined
  8. #8 Re: p0304 code and engine overheating!!!!!!!
    you still need to bleed the brass screw, open rad alone wont get it done.
  9. #9 Re: p0304 code and engine overheating!!!!!!!
    Asheville nc
    Thanks guys for the help. i will give this a try and post my the out come.
  10. #10 Re: p0304 code and engine overheating!!!!!!!
    Calgary
    actually you are only supposed to open the screw while filling not while running the car and the air will make its way out of the open rad just fine. look at the system the top of the rad is higher than the brass screw so........ Guess where the air will go!!! you got it champ to the top of the rad where there is the.......... Open rad cap!
  11. #11 Re: p0304 code and engine overheating!!!!!!!
    Quote Originally Posted by fst4dr View Post
    im not so sure about that. read this. http://www.grandprixforums.net/engin...ting-8778.html
  12. #12 Re: p0304 code and engine overheating!!!!!!!
    Calgary
    Alright you obviously know best! I will reconsider my current profession as an automotive technician
  13. #13 Re: p0304 code and engine overheating!!!!!!!
    quit then
  14. #14 Re: p0304 code and engine overheating!!!!!!!
    Calgary
    Yeah I know! **** what have I been doing with my life!
  15. #15 Re: p0304 code and engine overheating!!!!!!!
    Calgary
    I mean some internet cowboy forum jockey just showed me up!
  16. #16 Re: p0304 code and engine overheating!!!!!!!
    are you ok??? hang in there, its really ok
  17. #17 Re: p0304 code and engine overheating!!!!!!!
    SE Level Member Shang TI's Avatar
    Austin TX
    Pull the plug on #4 and see if any coolant is on it or and goopy stuff at all. When my car had a overheating problem it was my lower intake gasket and by overheating it my back head cracked lol it sucked so dont let it overheat shut it down if it goes too far past 210, and keep checking your coolant levels
  18. #18 Re: p0304 code and engine overheating!!!!!!!
    Bastard Reptile's Avatar
    Kansas City, MO
    I don't see any reason to be butthurt. Even after filling the radiator to the top, the coolant hose has a couple of bends in it that you've got to work at to get air out.
    As long as the end result is achieved, who cares?
  19. #19 Re: p0304 code and engine overheating!!!!!!!
    If you keep fighting... I've had a couple stubborn ones in the past. Try putting it on ramps to elevate the front and pull the rad cap to try and help air move around.
    If that doesn't do the trick, pull the T stat and ensure you fill the LIM up to the T stat, then put the stat back in and finish the rest of your burping procedure.
    Most of the time I don't bother with the bleeder screw. 90% are fine without it.. it's the 10% that it's there for. You seem to be in the 10% from the sound of it.
  20. #20 Re: p0304 code and engine overheating!!!!!!!
    Kansas City, MO
    I've always massaged the upper hose to push most of the air out while I fill it...then a quick turn of the bleeder usually helps top it off.
    Whatever works.
  1. Code p0304
    By gandprixgtpsuper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2011, 08:24 AM
  2. New Engine code ... OH NOOO!!!
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2010, 10:10 PM
  3. Engine keeps overheating
    By bigpapa53023 in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-30-2009, 07:05 PM
  4. Engine Code
    By the955iman in forum General Tech Discussion
    Last Post: 04-17-2009, 04:40 PM
  5. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
