Thread: Better Gas Mileage?
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Better Gas Mileage?
    GT Level Member Adidasdude1989's Avatar
    Jan 2012
    Sturgis, MI
    Ok so anyone have any tips? Im not a heavy footer but i feel like im consuming a lot of gas then i should be. No gas leak at all by the way.
    I know a dirty fuel filter can affect fuel economy a little bit right? When should i change that? Fuel injection cleaner? Anything about that?
    Thanks a lot to those for helping me as i post CONSTANTLY asking the random silly questions.
    Miles: 170-XXX
    Engine: 3.8L V6
    http://youtube.com/KBsVlog
  2. #2 Re: Better Gas Mileage?
    Jun 2011
    Clean MAF and TB.
  3. #3 Re: Better Gas Mileage?
    Jan 2012
    Sturgis, MI
    Quote Originally Posted by E IN v Y View Post
    Clean MAF and TB.
    TB?
    Miles: 170-XXX
    Engine: 3.8L V6
  4. #4 Re: Better Gas Mileage?
    ^ Throttle body
    04 Comp G.
  5. #5 Re: Better Gas Mileage?
    Jan 2012
    Sturgis, MI
    Should i use some fuel injection cleaner also?
    Miles: 170-XXX
    Engine: 3.8L V6
  6. #6 Re: Better Gas Mileage?
    Jun 2011
    Fuel injector fluid wont hurt anything.
  7. #7 Re: Better Gas Mileage?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    For your 98 I'd suggest removing the Throttle Body from the Upper Intake Manifold then remove the Mass Air Flow Meter. You'll have to go get the special torx bit(s) with the hole in the middle at the parts store and pick up a throttle body gasket. Remove the Mass Air Flow from the Throttle Body and clean them separate. Use Mass Air Flow cleaner on the MAF and Throttle Body cleaner on the Throttle Body. It's easier to get to everything good and you'll find a lot of carbon build up on the inside of the TB. Put everything back together carefully and taadaa.
    What's the average mileage one can go on a full tank of gas?
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  8. #8 Re: Better Gas Mileage?
    St. Louis
    Lets see....
    Clean MAF and TB
    New Plugs/wires
    New O2 sensor
    Seafoam in the gas tank and oil (about 50mi. before an oil change)
    Properly inflate tires
    Change air filter
    Remove any unecessary weight from vehicle
    Drive lightly (no WOT from a stop)
    Check for and repair any vacuum leaks
    In my 00 GPGT with a mix of city and highway (running the A/C) I can get about 410-420 on a full tank, which means from Full to completely empty. If not all the way empty since I like my fuel pump I get about 400mi. to a full tank, and that includes some WOT runs on the highway passing people.
  9. #9 Re: Better Gas Mileage?
    Pennsylvania
    Quote Originally Posted by dbextreme View Post
    Also should be noted to NOT touch the MAF wires inside with anything, just spray it down thoroughly with some pressure and let it air dry. Touching will result in you going back to the store to buy a new sensor.
    Sport Edition Kv5 18x8
  10. #10 Re: Better Gas Mileage?
    Jan 2012
    Sturgis, MI
    About 310, ive ran up to 317 before but as im thinking about it, as gas prices are crazy right now, usually put 6 gallons in but wow its gone within 150 miles it seems, i just think that needle is goin down quite fast...
    Miles: 170-XXX
    Engine: 3.8L V6
  11. #11 Re: Better Gas Mileage?
    Pennsylvania
    Quote Originally Posted by Adidasdude1989 View Post
    My 04 GTP makes about 330-350 miles on a tank, and I live in the mountains... lots of interstate though too. My DIC says average is 21.2mpg. Im hoping it'll go up now that I fixed my MAF issue.
  12. #12 Re: Better Gas Mileage?
    and most of it wont do anything.
    Use seafoam or STP complete system cleaner or best of all: GM fuel system cleaner.
  13. #13 Re: Better Gas Mileage?
    Nov 2009
    Tennessee
    HOLY CRAP!!! Then I got a problem to!!! LMAO
    My car runs fine, no problems, no SES light, and plenty of power. No matter how I drive I can only average 250 miles per tank......
    I have new LIM gaskets, UIM, Removed the throttle body and cleaned it and the MAF, new fuel filter, new plugs and wires, new downpipe, Ubend and Res delete... I do have a heavy foot, but nothing like WOT all the time... I was getting the same mileage before my engine fire to...
    Now I'm concerned.... LOL
  14. #14 Re: Better Gas Mileage?
    Sep 2011
    MI
    how big is your tank? mine is around 13 gallons and i get around 275 miles which is around 21 mpg. I drive city/highway combination.
  15. #15 Re: Better Gas Mileage?
    they're all around 17-18 gallons.
  16. #16 Re: Better Gas Mileage?
    Nov 2009
    Tennessee
    Every fill up (I always go from full to amost empty) is anywhere from 14.7 - 15.2 gallons on fill up... That's ~ 16.5 MPG
  17. #17 Re: Better Gas Mileage?
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    Quote Originally Posted by 99PontiacGTP View Post
    thats better than mine...i go from empty to full and its only 11 gal max...and i only get about 180 miles...roughly 17 mpg max...so that blows. i did plugs, o2 sensor, oil change recently...not sure what the heck is the deal...and not sure why i can only put 11 gal in from full empty, that or my tank sensor is WAY off
    GT Level Member iRideGTP's Avatar
    Jul 2012
    California
    according to my DIC i also only get 17 average mpg which really sucks. tb and maf cleaning is on the to-do list for sure
  19. #19 Re: Better Gas Mileage?
    17-19 mpg city is all these things are rated for. Hit traffic, expect 14 mpg or less.
    27-30 mpg requires freeway and careful driving, as in no accelerating to pass people and other nonsense like traffic.
  20. #20 Re: Better Gas Mileage?
    Jun 2011
    lol at what this thread has become.
    I get 25 MPGs... and i drive it like i stole it.
  1. Bad Gas Mileage
    By TheAce144 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2011, 02:47 PM
  2. low gas mileage?
    By coreygnar in forum General Tech Discussion
    Last Post: 06-07-2010, 09:44 PM
  3. Better mileage on an old V8 than a GTP LoL!
    By Juanmiguel in forum The Rant Forum
    Last Post: 01-28-2010, 09:26 PM
  4. Gas Mileage
    By cincygoat in forum General Tech Discussion
    Last Post: 01-28-2010, 12:08 AM
  5. What can I do to get better gas mileage?
    By isucyclones3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 11:58 PM
