Thread: spark plugs
Results 1 to 20 of 31
  1. #1 spark plugs
    SE Level Member 99gtp3's Avatar
    Apr 2012
    mn/wi
    hi my 99 gtp needs plugs, its stock besides cai.. i plan to do log and down pipe first just wondering if i should run oe ac delco's or somthing better i dont mind changing them sooner if a differnt plug is going to work better.. thanks
  2. #2 Re: spark plugs
    Sep 2011
    Southern Alberta, Canada
    most everybody here swears by ac delco coppers - they dont last as long but seem to work better.
    and when i say they dont last as long , coppers a few years - to double platinum that last a decade or more.
    There is a few threads on this in this forum.
    I have ac delco special double platinums - ultra fine wire center
  3. #3 Re: spark plugs
    GTX Level Member cerick08GP's Avatar
    IMHO the perfect plug for you is the autolite 605
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: spark plugs
    Apr 2012
    mn/wi
    wat is IMAO? lol sorry... so autolite 605's are best for minor bolt ons?
  5. #5 Re: spark plugs
    I n
    M y
    H umble
    O pinion
    IMHO
    Here is the deal guy...
    #1: Check out the link in my signature...read away till yer eyes bleed
    #2: You want the hottest spark you can get away with, not the coldest...contrary to popular belief...people thinking cold cold plugs can kill knock when in fact the car just runs crappier, gets junky MPG's...etc.
    #3: Cerick is right. For minor bolt-ons with a stock pulley, you want Autolite 605's...gap them at .050". I'd also recommend removing the coil packs, cleaning under them (getting rid of all the dirt and grime on the ICM that the coils sit on...), sand down and clean the coil pack terminals them selves...re-install...add a pea sized amount of electrical grease on the coil terminal...then toss on some new Lifetime warranty plug wires from your local auto parts store.
    That should do wonders for the car igntion wise, especially if it hasn't been done yet.
  6. #6 Re: spark plugs
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    I just met you.
    This is crazy, but run Iridiums, maybe?
  7. #7 Re: spark plugs
    Probably plans to mod past exhaust stuff...so then, meh...no.
  8. #8 Re: spark plugs
    St. Louis
    Quote Originally Posted by heavydtheogre View Post
    You do know these ignition systems don't particulary like platinum plugs, right? That's why we always recommend the copper or irridiums due to the plats getting chewed up by our waste-spark system. If you start getting misfires or a rough idle I'd check the plugs.
  9. #9 Re: spark plugs
    Denver
    I've run every brand and every type in my car. The only ones I've ever had problems with were Champion copper core plugs.
    Not a single problem with Bosch Pt, NGK Ir, NGK Pt, Delco Pt.
    Since changing the back ones are such a royal PITA, I would get Pt or Ir.
  10. #10 Re: spark plugs
    Quote Originally Posted by SJAndrew View Post
    Back plugs are easy.
    The last kind of plug you want is a Platinum in these cars.
    Iriduims are for stock cars only.
  11. #11 Re: spark plugs
    Ocala, FL
    Quote Originally Posted by mechguy View Post
    I just met you.
    All the other plugs
    Try to beat them
    but run iridiums, maybe?
  12. #12 Re: spark plugs
    Dec 2010
    Canada
    Quote Originally Posted by codyAK View Post
    All the other plugs
    Try to beat them
    Before iridiums came into my life,
    I changed plugs so often
    I changed plugs so so often
    I cleaned, gaped and replaced
    Have new wires for real
    I didn't know copper won't last
    But they were in myyyy car
  13. #13 Re: spark plugs
    Pennsylvania
    There's art in here.
  14. #14 Re: spark plugs
    The lies, slow.
    THE LIESSSS
  15. #15 Re: spark plugs
    Sep 2011
    I do like coppers, and the platinums i have are really good, and i do believe because they are tapered, and double platinums.
    The ones in my car are atleast 4 years and show no wear, but regular and double platinums dont flow as much spark energy as coppers.
    My tapered center DP's may not produce the same spark as coppers, but the car runs great, and no problems.
    But Coppers do produce a better spark, just because they are copper = copper conducts very well.
    and dont look ath the copper plugs funny, cause copper is goldish color and copper plugs are silver color - that is the nickel covering so they last longer.
  16. #16 Re: spark plugs
    Your 3100 does not apply the same logic here.
  17. #17 Re: spark plugs
    Sep 2011
    ok y's that?
  18. #18 Re: spark plugs
    ok y's that?
    Different motors like different style plugs.
    Simple concept.
    60* V6 =/= 90* V6
  19. #19 Re: spark plugs
    even though they both call for the same plug and use similar ignition systems?
    COOL.
  20. #20 Re: spark plugs
    COOL.
    Bro.
    You'd put the same plugs when both are are modded?
    I knew it.
  1. spark plugs
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2013, 03:34 AM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. spark plugs
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 09:44 PM
  4. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
  5. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
