Thread: GTP Seafoam Procedure - question
Results 1 to 6 of 6
  1. #1 GTP Seafoam Procedure - question
    Cambridge, Ontario Canada
    For top end cleaning:
    1. Make sure motor is cold
    2. Pull vacuum line on top of SC
    3. Take straw & let motor ingest 7 oz over the course of 2 minutes
    4. As soon as mixture is done, shut car off
    5. Wait 20 mins
    6. Fire up car
    7. Process sound right?
    I won't be driving the car, it will be parked do I rev a whole bunch & for how long?
    2005 E55 - stock
  2. #2 Re: GTP Seafoam Procedure - question
    Jul 2012
    Grand rapids
    If you do that your going to help it stay running by bringing up the rpms suck in the seafoam and shut the car off wait 10 15 mins. When you start it back up your going to want to be in an open area it will smoke like a mother$)@&$&' I usually drive around in 2nd gear or jump on the highway it works good
    Good luck let us know what happens
  3. #3 Re: GTP Seafoam Procedure - question
    The Boss Iceman6669's Avatar
    Jun 2011
    Grand Prixs Of North America • View topic - Seafoam writeup
    Thats the write up i used.. Worked VERY well...
    2011 F-150 Yote powered
  4. #4 Re: GTP Seafoam Procedure - question
    Pennsylvania
    Some people have said that vac line on top of the blower will bring the seafoam through the rotors which can harm them.
    I was advised to use the vacuum line off the bbv
    If you follow it back, it goes directly into the LIM, bypassing the supercharger. Worked for me and others and doesnt risk the blower.
    Just dunk that hose into the can as far in as you can get it, and let it drink up... mine slurped up the whole can in about a minute or so. Then run around and shut it off as fast as you can.
    Sport Edition Kv5 18x8
  5. #5 Re: GTP Seafoam Procedure - question
    Will i have a problem if i do seafoam. Start car and let run for 10 mins then not drive it for a week or so? Or will seals and **** get a beating?
    2005 E55 - stock
  6. #6 Re: GTP Seafoam Procedure - question
    Did the seafoam. Let sit for 10 mins. Ran car for about 10 mins & let sit since. I didn't get nearly as much smoke as some cars I have seen. Used about 5 oz or so. Pulled in through the vacuum hose on the bbv & shut car off right way once sucked up. One thing I did notice was a fair bit of stuff coming from engine bay. Looks like I might have a few small leaks in the front & rear header areas.
    2005 E55 - stock
  1. Procedure for dropping the oil pan on GTP?
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2011, 06:18 PM
  2. Brake Bleeding Procedure
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 06:20 PM
  3. seafoam question.
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:34 PM
  4. Procedure to program the BCM
    By darinparsons99 in forum General Tech Discussion
    Last Post: 10-26-2009, 09:30 PM
  5. Procedure for changing diff while in the car.
    By machine head in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2009, 03:15 PM
