Thread: GT stuttering and dying
Results 1 to 9 of 9
  1. #1 GT stuttering and dying
    Jul 2012
    north pole
    ok i have a 2000 gt that stutters occasionally and randomly dies, usually while stopped but sometimes at speed. This seems to happen more when the air is on but not limited to that. i was told the map sensor was replaced several times and this fixed it but obviously if it needs to be replaced all the time something else is going on. any help would be greatly appreciated thanks
  2. #2 Re: GT stuttering and dying
    Has the tach ever dropped to zero, then say 5ish seconds later the car dies?
  3. #3 Re: GT stuttering and dying
    Jul 2012
    north pole
    dont think its ever dropped to zero then died, although im not saying it hasnt done that. now several times the tach has dropped to zero while the car was stuttering and then started idling again
  4. #4 Re: GT stuttering and dying
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    You might have a vacuum leak? Mine did the same thing until a saw a massive vacuum leak near my throttle body
  5. #5 Re: GT stuttering and dying
    Lifer h0wl0ngcanitbe's Avatar
    Marysville WA
    Have you checked your MAF or Idle Air Control?
    2001 4dr Black GTP Stock and staying that was... maybe
    1997 2dr Black GTP Open Cone, GXP Rims, Black Headlights, ZZP Headers, ZZP Cat Back, Bunch of suspension parts from ZZP, ZZP 10.5MM plug wires, Autolite 605s, Overkill Tune
  6. #6 Re: GT stuttering and dying
    Jul 2012
    north pole
    i believe i was wrong when i said map sensor, i believe the MAF has been replaced several times, my mistake guys. i have never checked the idle air control i'm gonna check into that and the vacuum leak. i'll let you know if that helps. at any rate thanks for the suggestions, at least now i have somewhere to start.
    any chance it could be the fuel filter, my gf is notorious for driving this car to the point the gas light comes on...
  7. #7 Re: GT stuttering and dying
    Marysville WA
    Might as well replace it if its even a thought, takes like five minutes to replace.
  8. #8 Re: GT stuttering and dying
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Driving the car on a low tank won't hurt your fuel filter but it will hurt your fuel pump by overheating it. Check your fuel pressure it should be 53-59 psi with the key on engine off. If it's not within spec replace the filter since it's good matinence to anyways hopefully that fixes it. if not then i'd start checking your fuel pump
  9. #9 Re: GT stuttering and dying
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Is it throwing codes, SES light on? Any weird smells from under the car when it's hot?
    Could this be EGR related?
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. Battery keeps dying...........
    By mallard22 in forum General Grand Prix Discussion
    Last Post: 05-08-2012, 11:37 AM
  2. Random Car Dying?
    By crock in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-20-2011, 10:19 PM
  3. 01 gt dying a lot
    By Cummins97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 09:18 PM
  4. question about car dying
    By clovewell in forum General Tech Discussion
    Last Post: 02-04-2010, 04:11 PM
  5. Car keeps dying
    By jakeeck in forum General Tech Discussion
    Last Post: 02-19-2009, 12:26 AM
