Thread: question about car dying
Results 1 to 8 of 8
  1. #1 question about car dying
    Feb 2010
    kansas
    I have a 2001 Pontiac Grand Prix GT. I have had a problem for some time. While driving the car the tachometer will drop to zero and stop working. Sometimes this causes a shutter and other times the car will die completely. Most of the time the car will start right back up, other times it will take several minutes to start. On one instance where it took awhile to start, it back fired. I don't know if this is a spark plug issue, a ignition coil issue, a fuel system issue or what. If anyone has had this same problem I would greatly appreciate knowing what you did to fix it.
  2. #2 Re: question about car dying
  3. #3 Re: question about car dying
    Feb 2010
    kansas
    I take it you have had this problem before?
  4. #4 Re: question about car dying
    not me personally, but ive seen it enough that i can diagnose it fairly well.
  5. #5 Re: question about car dying
    Feb 2010
    kansas
    Thank you. I looked and the sensor seams pretty cheap and the fix is some what simple. I will try this and see what happens. Is there anything else that could also be causing this problem along with the sensor that you know of?
  6. #6 Re: question about car dying
    Had the same symptoms with the tcs light coming on, it was the cps.
  7. #7 Re: question about car dying
    Feb 2010
    kansas
    CPS?
  8. #8 Re: question about car dying
  1. Intermittent dying problem with 00 GTP
    By ls6velless454 in forum General Tech Discussion
    Last Post: 04-08-2010, 12:11 PM
  2. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
  3. Ok dumb question i been dying to ask!!!
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-18-2009, 03:04 AM
  4. Car Randomly Dying... Well Kind of....
    By MaximusNeo701 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-04-2009, 05:50 PM
  5. Car keeps dying
    By jakeeck in forum General Tech Discussion
    Last Post: 02-19-2009, 12:26 AM
