2004 Pontiac GT 3800 Series 3.
Recently, the power steering pulley fell off, thus the belt, which caused the engine to overheat. Everything got put back together, but now the car's been losing coolant and overheating again. After taking it for a drive and temp. needle nearing the red zone, pulled in the driveway and noticed a hissing sound. Found the hissing coming from a plastic elbow out of the block and into a passage between the water pump and tensioner. How do you replace this elbow? Does it just push into the block and into the passage under the tensioner, screw in or what? Do I need to remove anything to change this? Are there any other elbows I should be looking at, and if so, where are they located? Water pump does not appear to be leaking, so I'm thinking this may be my only problem. There is enough coolant in the system right now, and though I'm losing it, it's not losing a lot but still overheating the engine. Thanks for any help.
