From the plug diagram I have, it says plugs are getting too hot. (Recomendations) Check for the correct plug heat range, over advanced ignition timing, lean fuel mixture, intake manifold vacuum leaks, sticking valves and insufficient engine cooling. This is what my book is saying. Hopefully it helps you.
