Thread: I have a miss. :(
Results 1 to 19 of 19
  1. #1 Re: I have a miss. :(
    TDCRacing
    Guest
    Bad injector. Or coil pack.
    Can you explain the problem more. Like exactly what is happening. Ill bet money on it that it is an injector.
  2. #2 Re: I have a miss. :(
    TDCRacing
    Guest
    Those injectors are to small also. Stock is what 24lbs I belive. Also if you put different injectors than what the stock flow rate is you have to rescale the injector table inside of the pcm with a tuner.I see you said you replaced the injector? With a new one? Sure you changed out the one that was messing up?
  1. Check engine light and horrible miss...
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2008, 07:53 PM
  2. Miss Prixx is now here..
    By miss prixx in forum Introductions/Noob Questions
    Last Post: 01-08-2008, 01:16 AM
