How to fix it:
If you take the bottom cover off of the steering column you can get to it rather easy and remove the solenoid.
1) tilt wheel all the way up and remove tilt wheel lever.... just pull, it comes out rather easy
2) take out screws in bottom steering column cover.... torx bit
3) pull off cover. you will have to tilt it a little to clear the rear clips.
4) remove screw(s) holding in solenoid.... very small nut driver or pliers will do the trick.
5) unplug wires to solenoid and discard solenoid into nearest trash can and save money for beer after job is complete
6) reverse order to reassemble column
7) use money saved from step 5 and go have a few beers
**It keeps you from being able to take your key out in anything but park. If you try, you will be able to turn your car off and take out the key in any gear now. Not a good idea if you want your car to still be in the same place as where you parked it.
I worried about it when I removed mine, but not really anymore. I've not even come close to accidentally parking it any anything but park.
