Thread: Perf Shift
Results 1 to 16 of 16
  1. #1 Perf Shift
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    how would one go about getting performance shift on a car without performance shift already on the knob?
    would i just need a new knob? or would i need a whole transmission?
    and finally, the big question, is it worth it?
    Dec 2010
    DMV
    Not worth it. At all. What year is your car? The later models had performance mode built into the PCM and its always on I believe.
  3. #3 Re: Perf Shift
    perf shift makes a big difference in how the car shifts, you can have you pcm tuned to up the line pressure in your trans, and firm up the shifts.
    i think i did read somewhere that you can wire the button up but you need to put the wires into the pcm by pining it into the harness plug i believe. there was a write up some where.
    i think charlie the van man swapped over the perf shift button into the mini van.
  4. #4 Re: Perf Shift
    Mar 2012
    Minneapolis MN
    i have a 1998 Bluemagic.
    Was that write up in the illustrious and inaccessible how to section?
  5. #5 Re: Perf Shift
    are you supercharged or N/A?
  6. #6 Re: Perf Shift
    Mar 2012
    Minneapolis MN
    N/A
  7. #7 Re: Perf Shift
    not sure if its even an option for a N/A, unless its tuned into the pcm and runs full time. could do a shift kit. that will firm up your shifts.
  8. #8 Re: Perf Shift
    Mar 2012
    Minneapolis MN
    i have all the places for it on my DIC and instrument cluster.
    This seems like it would work though doesnt it?
    DIY Performance Shift installation Write Up. - Grand Prix Net
  9. #9 Re: Perf Shift
    looks like it may work.
    wait till Monday for better answers, some one will see this and comment.
    Mar 2012
    Minneapolis MN
    So any other opinions?
  11. #11 Re: Perf Shift
    I have opinions. Which ones you want?
    Perf shift was typically not noticable on stock transmissions past 30-50K miles. It's only a couple hundred rpm difference. You can add it if you put in a DHP file to add that opt and wire in a switch.
    Mar 2012
    Minneapolis MN
    You say on a stock transmission, let's say I throw in like a thrasher shift kit, and then also dhp the performance shift in. Would it be more noticeable?
  13. #13 Re: Perf Shift
    If you have the dhp out to program it. Make it more than 200 rpm difference and up the line pressure enough to notice it.
    However from your previous posts. You likely have other issues that you should be fixing before going into something like this.
    Mar 2012
    Minneapolis MN
    Yes yes I know. I just like knowledge I like knowing everything I can before I start acting on it haha
  15. #15 Re: Perf Shift
    In that case
    Counter clockwise typically loosens
    Clockwise typically tightens
    You own a GP. You'll need that info.
    Mar 2012
    Minneapolis MN
    I grasped that
  1. 98 gtp perf shift
    By lisas1998gtp in forum General Tech Discussion
    Last Post: 05-06-2010, 12:29 PM
  2. perf shift not working (not the button)
    Last Post: 04-23-2010, 10:55 PM
  3. Do I need to activate Perf. Shift in stock pcm for it to be enabled?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 10-18-2008, 04:27 PM
  4. PERF SHIFT light?
    By RichCresci in forum General Tech Discussion
    Last Post: 07-21-2008, 08:35 PM
  5. Perf shift question.
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 08:44 PM
