Thread: 98 gtp perf shift
Results 1 to 2 of 2
  1. #1 98 gtp perf shift
    SE Level Member lisas1998gtp's Avatar
    texas
    doesnt work i tested the swich its good. what else do i look at? just got a new trans and stil doesnt work. no light or change in performance.
  2. #2 Re: 98 gtp perf shift
    Wichita
    I had a similar problem. I'd click on the Performance Shift button & the DIC would only blink 'Performance Shift'. The light did not stay on. I came to find out the wiring wasn't plugged in properly. Fiddled with it & mine works again. Check to see if your Performance Shift is plugged in properly if it is at all. It may have been disconnected when your tranny was installed.
  1. perf shift not working (not the button)
    By lisas1998gtp in forum General Tech Discussion
    Last Post: 04-23-2010, 10:55 PM
  2. 4T65E HD tranny swap and perf. shift question
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 11:49 AM
  3. Do I need to activate Perf. Shift in stock pcm for it to be enabled?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 10-18-2008, 04:27 PM
  4. PERF SHIFT light?
    By RichCresci in forum General Tech Discussion
    Last Post: 07-21-2008, 08:35 PM
  5. Perf shift question.
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-30-2008, 08:44 PM
