Okay. I did a little further research and the firewall around the heater hoses is dry. The elbows are also dry. I did stumble across another clue.
I might have had too much antifreeze in the cooling system. I replaced the broken over flow tank and when my leak still appeared I put my finger around the drain pipe on the top rear area of the tank. I got antifreeze on my finger. I removed some of the coolant from the tank and cleaned everything up.
I ran the car today and so far I don't see any leakage. Maybe I added too much to the overflow tank when I replaced it.
