Thread: Urrrgh, electrical issues!!! Fog light switch turns on hi-beam indicator?
Results 1 to 17 of 17
Threaded View
copgtp Urrrgh, electrical issues!!!... 04-27-2012, 08:34 PM
copgtp Re: Urrrgh, electrical... 05-03-2012, 05:01 PM
copgtp Re: Urrrgh, electrical... 05-03-2012, 11:18 PM
BillBoost37 Re: Urrrgh, electrical... 05-04-2012, 06:05 AM
Swiggles Re: Urrrgh, electrical... 05-04-2012, 12:29 PM
copgtp I got sick, so no testing... 05-05-2012, 03:13 PM
copgtp Re: Urrrgh, electrical... 05-06-2012, 11:55 PM
Rico Re: Urrrgh, electrical... 05-07-2012, 12:54 AM
copgtp Re: Urrrgh, electrical... 05-07-2012, 09:28 AM
BillBoost37 Re: Urrrgh, electrical... 05-07-2012, 09:45 AM
copgtp Good call bill, ill double... 05-07-2012, 11:24 AM
BillBoost37 Re: Urrrgh, electrical... 05-07-2012, 11:25 AM
copgtp Lmao ;) I fixed it!!!! ... 05-07-2012, 12:00 PM
BillBoost37 Re: Urrrgh, electrical... 05-07-2012, 12:22 PM
copgtp Alright, so I checked the... 05-13-2012, 11:39 AM
Poil336 Re: Urrrgh, electrical... 05-13-2012, 08:04 PM
copgtp Re: Urrrgh, electrical... 06-01-2012, 10:10 PM
  1. #1 Urrrgh, electrical issues!!! Fog light switch turns on hi-beam indicator?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Alright, so a little background. The car's lights all worked perfectly fine before I tore it apart 2 years ago.
    35w HID low beams, 35w HID fogs, both have upgraded harness.
    Putting it back together, I swapped out to new digital slim ballasts, and swapped my old spyder halo's for the newer CCFL halos...........
    Alright, so I have the parking light situation pretty much figured out, seems like the LED switchbacks may be causing the problem.........
    But I'm still having an issue with the fogs........
    when I hit the switch in the cab, the switch doesn't light up........ but the high-beam indicator goes on!?!?!
    Also, not getting any power with the switch on to the ballasts........
    Checked my HID harness and relay for the fogs, that is in working order.
    So this leads me to believe that there is an issue within the hi beam / fog light wiring........ I know they share some wiring b/c when you turn the hi beams on, it usually shuts off the fogs, so it seems to me like something is up...........any ideas or where to start troubleshooting this?
    UPDATED: 5/7/12
    For all your 3800 needs:
  1. Electrical Issues
    By DStepien in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2012, 10:06 PM
  2. Car issues - electrical and key
    By JJ133169 in forum General Tech Discussion
    Last Post: 06-20-2011, 07:20 PM
  3. possible electrical issues
    By jcmonteman in forum General Tech Discussion
    Last Post: 04-18-2011, 05:47 PM
  4. Left Front Speakers don't work...
    By Gannon2145 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 07:56 PM
  5. The Electrical Work Is Done!!
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2008, 03:43 PM
