Thread: Measurements
Results 1 to 7 of 7
  1. #1 Measurements
    Apr 2012
    Illinois
    can anyone help me with rebuilding a 98 gtp its been in an accident, i got all the parts but i just need fender to fender measurements and strut tower bolts to engine mount bolts
  2. #2 Re: Measurements
    Apr 2012
    Illinois
    bump
  3. #3 Re: Measurements
    Apr 2009
    Fort Worth TX
    Please explain the extent of the damage and some pictures would be great. A better description of the measurements you're in need of would be helpful.
  4. #4 Re: Measurements
    Maybe a trip to a JY?
  5. #5 Re: Measurements
    HUDSON
    Measuring from the shock tower to the motor mount may not be accurate becuase of the subframe bolts to the unitbody and there may be a large tollerence window. This there will be a large difference from car to car, althought it will be just mm.
    Unless you hhave strustural damage and can visible see buckle in unitbody, just hange the body panels and see how they line up. If you do have structure damage than a frame shop should be hired to put it back in shape with a frame and body rack that can pull back into shape properly. If damage is very minimal, just straighten the metal out with hammers.
  6. #6 Re: Measurements
  7. #7 Re: Measurements
    Apr 2012
    Illinois
    matt5112 thank you very much!
  1. SPO grill measurements
    By NegativeOne13 in forum General Tech Discussion
    Last Post: 11-08-2011, 10:34 AM
  2. Lateral Bar Measurements
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 12-12-2010, 02:18 PM
  3. Sunroof Measurements
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2010, 12:18 AM
