Thread: Door problem need Help
Results 1 to 10 of 10
  1. #1 Door problem need Help
    Lancaster,WI
    My driver door on my 96 Grand Prix SE won't open from the inside or outside I have been told I need to tear my door off but there is a problem i need the door open to do it so if someone could give my an idea i would appreciate it.
    96 Grand Prix
  2. #2 Re: Door problem need Help
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    someones gott a be .... the door is unlocked right? if it only opened from the inside its a door handle. its a common problem.
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  3. #3 Re: Door problem need Help
    Jul 2010
    Lansing IL
    my outside door handle broke on my drivers side. before you take it all apart you can adjust the linkage on it. ive had to do that on both of my doors. all you need to do is open the door and then take the inner cover of that is in the door jam and then ytou have access to the linkages and can see if it is a door handle or just a simple linkage adjustment
  4. #4 Re: Door problem need Help
    illinois
    My problem is similar but a little more complex. My door will not open from the outside or inside, so I cannot take the door panel off to fix the linkage. Any suggetsyions? Also, one of the rods seems loose near the door handle from what I can tell trying to pry the panel as far open as I can. Since it's not visible how do you know where it attaches? Does anyone have a linkage diagram I could see?
  5. #5 Re: Door problem need Help
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i know this is old but are you still having problems?
  6. #6 Re: Door problem need Help
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    If hes been climbing in and out from the passenger door all this time I will probablly die from laughing
  7. #7 Re: Door problem need Help
    Nov 2010
    Illinois
    Lol! It would be pretty sad
  8. #8 Re: Door problem need Help
    SE Level Member oldtimer3's Avatar
    Jun 2011
    texas
    Glad ya'll haven't seen me then, felt like the dukes of hazzards every once in a while. Kinda got it figured out what I need to do, but a picture or drawing would be nice.
  9. #9 Re: Door problem need Help
    You need to pull the door panel to fix the issue. That's the tough part. The best potential way to get at it would be to pull the drivers seat. That'll give you some room between it and the panel. From there, it's a matter of disassembling and trying to not destroy it while pulling it off in a way it wasn't designed to be pulled.
  10. #10 Re: Door problem need Help
    Jun 2011
    texas
    Adjusted the linkage, solved that little problem.
  1. HELP HELP! 99 grand prix 2 door DOOR HINGE REPLACEMNT
    By blortz in forum General Tech Discussion
    Last Post: 05-31-2011, 08:52 PM
  2. Auto Door Lock Problem-2000 GTP
    By sandjaso in forum General Tech Discussion
    Last Post: 08-31-2009, 07:25 PM
  3. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
  4. Power Door Lock Problem-O
    By flynn in forum General Tech Discussion
    Last Post: 12-31-2007, 04:49 PM
