Thread: Front-end shake
Results 1 to 16 of 16
  1. #1 Front-end shake
    Sep 2011
    Canada
    This is driving me nuts! I've checked everything and it all seems tight! When I am driving around 90kph (50mph) I have a horrible shake in the front end. I feel it on the floor beneath my feet, and in the steering wheel. I feel it more when I hit the gas or going uphill. I have replaced both my axels. I also get it when braking hard downhill. I have new pads and rotors. I thought of wheel balance issue as well, but I have new tires in the front that were balanced recently.
    I'm left with motor mount or struts. Can bad struts cause this as well? It's fine at speeds less than 90kph. It was so bad on the highway that I don't think I should drive it again on the highway. And insight is helpful.
    I have a 2000 GTP.
  2. #2 Re: Front-end shake
    Alignment?
  3. #3 Re: Front-end shake
    GTX Level Member cerick08GP's Avatar
    I'd say it was your new tires. Maybe they are out of round, or out of balance. The easy check is do a front to back rotation and see if the shaking shifts or not.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: Front-end shake
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    my guess is either the alignment is off, the rim is bent or a bad wheel bearing/bearings
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  5. #5 Re: Front-end shake
    Sep 2011
    Canada
    I'm going to check the wheels for balance. However, when I was coasting downhill in cruise control there was almost no shake. It seems to be when the tranny is under torque. I'll check the engine and tranny mounts too.
  6. #6 Re: Front-end shake
    Apr 2009
    Fort Worth TX
    Are there any DTC's?
  7. #7 Re: Front-end shake
    Sep 2011
    Canada
    Quote Originally Posted by Rico View Post
    Nope, no check engine light or abs light on.
  8. #8 Re: Front-end shake
    If you let off the gas and it goes away it almost sounds like a motor or trans mount.
  9. #9 Re: Front-end shake
    Apr 2009
    Fort Worth TX
    What I would do is:
    Put safety break on
    Turn key to on position (do not start)
    Depress break and put in neutral
    Open hood
    Reach across motor and grab alternator and bracket
    Push and pull on motor front to back as hard as you can
    There should be just about no movement at all. Even a half inch of play from front to back will cause some vibration.
  10. #10 Re: Front-end shake
    Oct 2011
    Michigan
    if the mounts are factory then feel around them if there liquid on them (that isnt from something else) then there shot
  11. #11 Re: Front-end shake
    Sep 2011
    Canada
    Rico, I was looking for an easier way to check the mounts, thanks for the how-to.
    asite57, the mounts are definately factory. I know I have a leaking rear valve cover and had a leaking power steering line before I replaced it. I haven't gotten to the rear valve cover yet, but it's a good point that leaking fluids over time can cause the bushings in the mounts to detiorate.
  12. #12 Re: Front-end shake
    Apr 2009
    Fort Worth TX
    asite57 was actually referring to the "OEM liquid filled" mounts. Sometimes they'll leak when they go bad. Check if they are leaking, both engine and tranny mounts.
  13. #13 Re: Front-end shake
    Oct 2011
    Michigan
    ^^^ this
    thats what i ment
  14. #14 Re: Front-end shake
    Sep 2011
    Canada
    Didn't know the mounts were liquid-filled on the GTP. I'm guessing the after market mounts aren't.
  15. #15 Re: Front-end shake
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by mrfreez View Post
    Good point. I'm not sure either. Maybe someone knows?
  16. #16 Re: Front-end shake
    Oct 2011
    Michigan
    You can buy nonliquid filled mounts
  1. shake raddles
    By Glider Girl in forum Audio, Security & Visual Electronics
    Last Post: 10-17-2011, 04:02 AM
  2. Front end shake from engine
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 08:21 PM
  3. HID Shake
    By NewBoost1997 in forum General Tech Discussion
    Last Post: 09-21-2011, 10:49 AM
  4. Front end shake/vibrate please help
    By cbcollins in forum Introductions/Noob Questions
    Last Post: 07-01-2011, 07:03 AM
