Thread: Changed my battery and now the car doesnt turn over as well.
Results 1 to 20 of 20
  1. #1 Changed my battery and now the car doesnt turn over as well.
    Jul 2010
    Canada
    I just changed my battery out for a new one. It is the right battery for my model and year but since I changed it it doensnt turn over as well when starting. How come and what could be the cause?
  2. #2 Re: Changed my battery and now the car doesnt turn over as well.
    Jun 2011
    Detroit, MI
    What battery did you get? Have you let it charge up all the way yet?
    iLoveSpade
  3. #3 Re: Changed my battery and now the car doesnt turn over as well.
    Jul 2010
    Canada
    No I havent charged it up yet how long do I do that for? How long do I leave the car running
  4. #4 Re: Changed my battery and now the car doesnt turn over as well.
    Jun 2011
    Detroit, MI
    just let it run for like 15 minutes and rev the engine a bit or go for a drive. What kind of battery though?
    iLoveSpade
  5. #5 Re: Changed my battery and now the car doesnt turn over as well.
    Jul 2010
    Canada
    AC Delco
  6. #6 Re: Changed my battery and now the car doesnt turn over as well.
    Jun 2011
    Detroit, MI
    it shouldn't be bad just let it run for a good amount of time or just drive it how you normally would and it will charge. Let us know if this doesn't help!
    iLoveSpade
  7. #7 Re: Changed my battery and now the car doesnt turn over as well.
    Jul 2010
    Canada
    Thanks for your Help Hippo Machine.
  8. #8 Re: Changed my battery and now the car doesnt turn over as well.
    Quote Originally Posted by Hippo Machine View Post
    If your battery is not fully charged you should put it on a charger, from what I have read charging the battery this way is not good for your charging system and can cause damage.
  9. #9 Re: Changed my battery and now the car doesnt turn over as well.
    Jun 2011
    Detroit, MI
    You're alternator is constantly charging the battery when your car is on, this does no damage to it. Whenever my battery is low this is how I do it...
    Your car ever been jumped?
    iLoveSpade
  10. #10 Re: Changed my battery and now the car doesnt turn over as well.
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Ok I had the same problem when I changed my battery, the problem is the connection , you need to make sure the negative and positive go all the way into the posts , I mean alll the way to the bottom of the post and make sure you tighten them really good. The reason for the stutter start is that the negative and positive arent making good contact.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  11. #11 Re: Changed my battery and now the car doesnt turn over as well.
    Jul 2010
    Canada
    I have them almost all the way to the bottom of the post there is just a small gap. I cant seem to get them any lower. Do you have any suggestions to get them lower. I have hit them gently on all sides and tried to wiggle back and forth but they just wont make it to the bottom. They are clean as well.
  12. #12 Re: Changed my battery and now the car doesnt turn over as well.
    Jun 2011
    Detroit, MI
    Idk if anyone else would suggest it but a rubber mallet..
    iLoveSpade
  13. #13 Re: Changed my battery and now the car doesnt turn over as well.
    Jan 2009
    I used a flat head screwdriver then hammered around the terminals to ensure they where all the way down and I believe its a 10 mm to bolt them down .
  14. #14 Re: Changed my battery and now the car doesnt turn over as well.
    Jan 2009
    make sure they are bolted really tight , if you see a gap or the terminal moves that means that they aren't tight enough and therefore the contact is not 100%.
  15. #15 Re: Changed my battery and now the car doesnt turn over as well.
    Jan 2012
    Philadelphia
    why is everyone posting questions in this thread?
  16. #16 Re: Changed my battery and now the car doesnt turn over as well.
    Jan 2009
    Quote Originally Posted by gtpeddie View Post
    "What you talking about Willys?"
  17. #17 Re: Changed my battery and now the car doesnt turn over as well.
    Jul 2010
    Canada
    Flat head and a hammer works just fine. Thanks for the advice.
  18. #18 Re: Changed my battery and now the car doesnt turn over as well.
    Jan 2012
    Philadelphia
    this thread is for how to write up not for people to ask questions, it say right in the sticky do not post questions in this thread
  19. #19 Re: Changed my battery and now the car doesnt turn over as well.
    Dec 2011
    Philadelphia, PA
    u just asked a question in this thread, now the jokes on you haha
    AEM bruteforce intake
    Diablo 93 Octane tune
  20. #20 Re: Changed my battery and now the car doesnt turn over as well.
  1. Dont like to turn left but easy to turn right
    By Randall in forum General Tech Discussion
    Last Post: 02-01-2013, 12:11 PM
  2. Changed Power Steering Pump and Wheel is still hard to turn...Why??? Plz Help!!
    By nickdemio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-23-2012, 05:57 AM
  3. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  4. happy just doesnt cut it
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-27-2008, 01:55 PM
