Thread: Losing Coolant from Overflow tank
Results 1 to 5 of 5
  1. #1 Losing Coolant from Overflow tank
    Pittsburgh
    Coolant coming out of overflow tank after shut off. It bubles like a caldron and then runs on the ground from the tank. I checked the hoses and they are good. Replaced T-Stat and bled system. It does not overheat in traffic but the temp does get high.
    Can this be the LIM?
  2. #2 Re: Losing Coolant from Overflow tank
    Charles City, IA
    It leaks out of the top?
    SMGPFC Two Nipple General
  3. #3 Re: Losing Coolant from Overflow tank
    Pittsburgh
    Leaks out of the little nipple on the back near the firewall.
  4. #4 Re: Losing Coolant from Overflow tank
    New Jersey
    is your rad cap any good?
    The rad cap is what regulates the pressure in the system. If its not sealing good it will just allow it to all run into the overflow as it expands.
    The cap leaking can also cause overheating due to not running high enough pressure in the system to keep it from boiling.
  5. #5 Re: Losing Coolant from Overflow tank
    Pittsburgh
    just changed the cap yesterday and so far that seems to be the problem. Thanks!
  1. coolant overflow tank GM Part number anyone?
    By Liquifire in forum General Tech Discussion
    Last Post: 08-30-2012, 06:48 PM
  2. Cleaning coolant overflow ......
    By Pepino in forum General Tech Discussion
    Last Post: 05-26-2010, 07:23 AM
  3. Oil residue in overflow tank and radiator
    By outnumbered in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-06-2009, 09:38 PM
  4. Is there to be a tube INSIDE the overflow tank?
    By RM97 in forum General Tech Discussion
    Last Post: 05-15-2009, 08:29 PM
