OK, been looking around on all the forums to do with the GTP's and 3800's for a little while now about what all I'm getting myself into. To make a long story short I bought a bunch of parts about 3 years ago, and actually ended up parking my '99 GTP just right after getting the parts. Mostly because the car had many oil leaks and not to mention I added a Truck to the family. Anyways, gas prices on the rise, the 5.7 in the truck is starting to suck me dry, and I want to switch back to the car, so now it's time to put up or shut up and install all the parts or just fix the leaks and be done.
The car as it sits, currently has a ubend delete, 180 thermostat, colder plugs, a set of nice wires, CIA, and that's about it.
Parts that are sitting in the trunk include....
XP Hot Cam
105 springs/moded retainers/moded seals (zzp suggested)
Headers
High Flow Cat
shorter dogbones
3.4 modular pulley
new single timing chain and adjuster
HP Tuners software
gaskets etc and probably some more stuff I can't remember....
Anyway, I want to retain some of the MPG savings I can have with the car vs. the truck, but I'm also worried about my aging 146,xxx tranny, and I figure once I bolt everything to the engine I'll just blow that thing up. I've been fighting with myself for over a week now wheather to do the cam install or just fix the stuff that's wrong and do headers, pulley, cat. I mean from the way I'm looking at it, the oil pan is leaking so I'm going to pull the engine out anyway, I have a hoist, might as well. I mean adding the all the stuff I'll still be getting decent MPG right or not? I know alot of it has to do with the tuning of the PCM afterwords which I'm a novice at (might need a little help with that). I appreciate everyone reading thru my ramblings, any suggestions or real world info you can give me on this would be helpful. Thanks in advance!
