Thread: Keeping my new mechanic honest
Results 1 to 19 of 19
  1. #1 Keeping my new mechanic honest
    GT Level Member flash527's Avatar
    Indianapolis, IN
    Hey guys, just moved cities, and have been taking my car to a new shop. Was there yesterday and got a real hefty quote. just wanted to make sure its fair. soo heres the scoop:
    my back passenger caliper is leaking fluid. he said i should change both calipers or i can have pull to one side or uneven braking. is that true? $630 for both rear calipers, includes pads. he said he'd replace the one for $330
    left front wheel hub assembly is loose $365 to replace.
    thats it for now. doesnt even include my leaking rack and pinion, 4 bald tires, and my HUD jus crapped out last week. ooo well. thanks for the input : )
    04 GTP - FOTB, Intense PCM, 180* Thermo, SLP Headers, 3.4" ZZP Modular Pulley, Moroso Race Wires, 104 Plugs, TEP trans: 3.29's, Thrasher shift kit. Soon to come: 13 inch dual piston brakes, rims and tires, wideband tune by PRJ.
  2. #2 Re: Keeping my new mechanic honest
    If your willing to put in a little bit of man hours, a new HUB assembly isn't that hard to do at all. Just buy a new TIMKIN bearing from Autozone. Last I checked when I was down there they were $140 with a lifetime warranty.
  3. #3 Re: Keeping my new mechanic honest
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    New rear calipers are like $47 from the Zone and they are reletively easy to replace. . I think that the are available "loaded" w/pads for $60 or so. Do these yourself for sure, the front hub is a little more difficult but still not bad if you have any experience. I would for sure replace the brakes in a pair but the front hub you can do just one side.
    For what your mechanic wants you can take the difference and buy those new tires. If your really on a budget, you can purchase used tires at a lot of tire shops or the boneyard. You might be surprised at what you find, but you are taking your chances too.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  4. #4 Re: Keeping my new mechanic honest
    Kansas
    Do the work your self. Rockauto has timken bearings for 90 thats where i get mine. Labour done my self.
    SOLD 1999 GT Silvermist TS
  5. #5 Re: Keeping my new mechanic honest
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    the front bearing is cake -- as others have pointed out the Timkin is about $100 --- maybe an hour to change. You'd need the big socket and a decent sac to loosen the center nut on the axle.
    the rear / any brakes can be dicey if you have to open up the hydraulics, which you would to change calipers. you can end up ruining the master cylinder bleeding the system if you're not careful, not to mention twisting up funky old steel brake lines. That said if you're careful rear brakes aren't a hard job at all. As others have said $60 to $75 / each for loaded calipers, I'd change the rubber hoses as well ($15 each) and flush the entire brake system. $200 in parts --- maybe and probably 1.5 hours to change the calipers and flush the system.
  6. #6 Re: Keeping my new mechanic honest
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    yeah, both the jobs are pretty easy... but if you cant do it yourself, i would shop around some more. those prices do seem a bit steep. at least for where im at...
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  7. #7 Re: Keeping my new mechanic honest
    Nov 2009
    Grand haven
    Put your big boy pants on and learn how to DIY and save some coin too. Good way to learn how to start working on your own gp.
  8. #8 Re: Keeping my new mechanic honest
    SE Level Member Justin48's Avatar
    Groton, CT
    i agree with the above posts... do it your self if you have the tools.. if not or you are too scared look on craigslist under services there is a automotive section and there are tons of automechanics that are out of work and decided to start makeing money working on cars out of their garage for like 20-40 a hour... I was doing it when i was up in washington for a "beer fund" being the navy is my primary job save you some money...
    zzp mps 3.2-3.4", prj intercooler core, bosh pump, zzp stage 3 front mount, xp cam, 130# springs,double roller chain, 42.5# injectors, sd headers, 4" fwi, modified prj tune(inprogress) performance shift add, aem wide band, aeroforce.
  9. #9 Re: Keeping my new mechanic honest
    Charles City, IA
    You should be able to do that all yourself pretty easily. Calipers are 3 bolts, hubs are 5 bolts and a nut.
    SMGPFC Two Nipple General
  10. #10 Re: Keeping my new mechanic honest
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Quote Originally Posted by shawngtp View Post
    x2 on the big boy pants....a brake project is an easy way to get more comfortable working on your car and realizing what you can save...if you really don't think you can tackle it, don't take it back to that shop. Look around on craigslist and find a mechanic who will do it as a side job...make sure to find one that works at a shop or sound legitimate, no just a "yo I'll do ur brakes for $20" kind of thing.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  11. #11 Re: Keeping my new mechanic honest
    Indianapolis, IN
    Ok I think your all right, I need to start working on my car myself. And theres so many walkthroughs on this website alone, I'm sure I cant find the information I need. Next paycheck I'll order the parts and worse case scenario, I'll find a mechanic on Craiglist. Thanks for the tips!
  12. #12 Re: Keeping my new mechanic honest
    I do a lot of work for people on the side. I whole heartedly encourage them to look up parts on the various sites and find out what the parts cost. You should also be able to find the labor estimates on the same work. Multiply that times the shops hourly rate. If those things don't reasonably add up, then shop for a different mechanic.
    There will be incidentals that fall under misc shop supplies, like caliper grease, can of brake cleaner, some rags etc. Overall though that should add up to under $20.
  13. #13 Re: Keeping my new mechanic honest
    Pennsylvania
    I think the steep price comes from the Genuine GM part... which I think is somewhere in the $220 range.
  14. #14 Re: Keeping my new mechanic honest
    Jul 2010
    Houston, Texas, United States
    Quote Originally Posted by Jakegday View Post
    ^ This.
    For that price you could f-body upgrade or so it seems. Idk
  15. #15 Re: Keeping my new mechanic honest
    Quote Originally Posted by alkygto View Post
    i found used tires for 10 bucks on craigslist, and even came across a set of 4 with 75% tread for 50, but passed because i only needed 1 tire. so i wound up with a 10 dollar tire that has 1/2 it life left, im sure its the best tire i have on the car too at this time.
    if you do go used, inspect the tire the best you can for cuts and punctures. check the inside as well. one of the tires i first looked at had a nice curb rash on the side wall, so i went on to the next tire.
    i came across sets of rims and tires for 125 to 150, with good tires.
    and i also just swapped out my dead rack for a used one, cost 75 bucks and 4 house of my life, but well worth not paying 500 or more to have it done at a shop. the only tools need was a socket set that went up to 18mm and wrenches to the same 18mm.
    EDIT: holy crap this is a old thread, i should have checked the dates lol
  16. #16 Re: Keeping my new mechanic honest
    Indianapolis, IN
    Haha mo worries, I actually did the hub assembly myself with the guidance of a friend who is pretty good with cars. The caliper is leaking so slowly I didn't even replace it, and wont until it becomes a bigger problem. Thanks for the tips guys!!!
  17. #17 Re: Keeping my new mechanic honest
    Uh.. the caliper is part of the braking system. When that leak decides to gush or something else.. you are going to hit whatever is in front of you.
    I hope you aren't on the highway. Please choose to take what I mentioned above to heart and fix the leak
  18. #18 Re: Keeping my new mechanic honest
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Maybe he likes the idea of a sudden stop by the means of whatever is infront of him by chance that day hopefully its not another person
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  19. #19 Re: Keeping my new mechanic honest
    GT Level Member tcman49's Avatar
    Apr 2011
    Palm Coast, Florida
    That quote is on the really high side, get another quote somewhere else or get the work done by yourself or a buddy, that's your options.
    T to the minor C
  1. Big thanks to a honest member on here
    By whiney in forum Shops and Community Heroes
    Last Post: 11-12-2010, 01:37 PM
  2. Keeping headlights off during day but still on auto.
    By 07GPGXPSilver in forum Visual/Body Modifications
    Last Post: 07-07-2010, 05:48 PM
  3. Honest Turbo Opinion
    By Thexissilent in forum Turbo
    Last Post: 07-02-2010, 11:09 PM
  4. Keeping the family heirloom
    By 3ggplant in forum Introductions/Noob Questions
    Last Post: 05-04-2010, 07:50 PM
  5. Honest Answers Only
    By Scott B in forum General Tech Discussion
    Last Post: 07-08-2008, 08:41 PM
