Thread: 2000 gtp rack and pinion
Results 1 to 5 of 5
  1. #1 2000 gtp rack and pinion
    Apr 2012
    wi
    Does anyone know if all 2000 gtps have the variable assist steering racks in them. Just curious cause I need to buy a rack for mine and wanna make sure that this is what i need. Thanks in advance for any help!
    Jeremy
  2. #2 Re: 2000 gtp rack and pinion
    St. Louis
    Not sure. Take a look at the rack where the large rubber boot is down on the drivers side. If there is a small 2-wire harness coming from it then you have Magnasteer.
  3. #3 Re: 2000 gtp rack and pinion
    Apr 2012
    wi
    Ok I will check. I forgot to mention that it was a Daytona pace car edition I thought maybe if any would have it that would but I will have to take a look tomorrow I guess
  4. #4 Re: 2000 gtp rack and pinion
    on the sticker on the under side of the trunk lid, if you see FE3 or NV7 you have magnasteer.
    or look for the wires like fordman said.
  5. #5 Re: 2000 gtp rack and pinion
    Apr 2012
    wi
    Ok thanks guys!
  1. rack and pinion
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:53 PM
  2. P.S. Rack and pinion? PLEASE HELP!!
    By dwc1435 in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2011, 01:16 PM
  3. rack and pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 02-21-2011, 09:53 AM
  4. GTP rack and pinion
    By mikedinthecity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2010, 12:33 AM
