Thread: coolant problem need help!
Results 1 to 15 of 15
asite57 coolant problem need help! 04-02-2012, 04:14 PM
Scottydoggs Re: coolant problem need help! 04-02-2012, 04:16 PM
dsmuts Re: coolant problem need help! 04-02-2012, 04:17 PM
asite57 Re: coolant problem need help! 04-02-2012, 04:20 PM
dsmuts Re: coolant problem need help! 04-02-2012, 04:24 PM
asite57 Re: coolant problem need help! 04-02-2012, 04:26 PM
dsmuts Re: coolant problem need help! 04-02-2012, 04:29 PM
Scottydoggs Re: coolant problem need help! 04-02-2012, 04:35 PM
asite57 Re: coolant problem need help! 04-02-2012, 04:40 PM
Scottydoggs Re: coolant problem need help! 04-02-2012, 04:41 PM
asite57 Re: coolant problem need help! 04-02-2012, 05:07 PM
dsmuts Re: coolant problem need help! 04-02-2012, 05:08 PM
Scottydoggs Re: coolant problem need help! 04-02-2012, 05:09 PM
asite57 Re: coolant problem need help! 04-02-2012, 06:34 PM
dsmuts Re: coolant problem need help! 04-02-2012, 06:39 PM
  1. #1 coolant problem need help!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    so i did a back yard coolant flush today and after about 20min of driving the "low coolant" light comes on then is goes off after a little bit then it comes on and so on and so forth for probably 10 miles now im home the car doesnt even come close to over heating its actually pretty normal temps. i think i broke the level sensor i did pull the over flow tank out to clean it. im stumped
  2. #2 Re: coolant problem need help!
    add coolant and re bleed the system.
  3. #3 Re: coolant problem need help!
    You probably have an air bubble in there.
  4. #4 Re: coolant problem need help!
    Oct 2011
    Michigan
    should i bleed it through the spot on the tstat?
  5. #5 Re: coolant problem need help!
    yeah bleed it on top the thermostat housing.
  6. #6 Re: coolant problem need help!
    Oct 2011
    Michigan
    ive never bled the coolant before should i open the bleeder start it up and wait for the air bubbles to come out then when its a steady stream close it back up?
  7. #7 Re: coolant problem need help!
    you have to do it when the thermostat is open. When the car is warmed up open the bleeder and it should spit some bubbles out. Close it and reopen it a few times. When you get nothing but a steady stream there is no more air bubbles.
  8. #8 Re: coolant problem need help!
    i like to wait till the fans come on, that way you know the T stat is open, then open the bleeder. i leave the rad cap off the whole time, if coolant dribbles out dont worry about it.
  9. #9 Re: coolant problem need help!
    Oct 2011
    Michigan
    the cars cold right now you say i should start it up and let it idle till the tstat opens up at 195 degrees then open the bleeder and wait till a steady stream comes out?
  10. #10 Re: coolant problem need help!
    yes sir, thats how i do it.
    just let it idle till the fans come on, it can take up to 15 minutes.
  11. #11 Re: coolant problem need help!
    Oct 2011
    Michigan
    alright i bled it with the tstat open a lot of bubbles came out but i did it a few times and now its a steady stream, so i should be all set right?
  12. #12 Re: coolant problem need help!
    coolant light go out?
  13. #13 Re: coolant problem need help!
    you should be, just keep an eye on your gauge and check the level down the road.
    some people have had to to it over and over. i do it one time and im set.
  14. #14 Re: coolant problem need help!
    Oct 2011
    Michigan
    alright drove it about 10miles or so no light everything seems fine ill do it again if the light comes on but thanks guys very very helpful
  15. #15 Re: coolant problem need help!
    No prob glad to help.
  1. coolant problem
    By asite57 in forum General Tech Discussion
    Last Post: 01-21-2012, 05:30 PM
  2. '99 GT Coolant problem
    By VGPGT in forum General Tech Discussion
    Last Post: 01-18-2012, 06:46 PM
  3. coolant problem
    By 73pontiac in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-20-2011, 02:10 PM
  4. Coolant leak problem WTF
    By KwazrollinZ28GTP in forum Off Topic Discussion
    Last Post: 12-10-2010, 06:28 AM
  5. coolant problem and radiator
    By colindunn in forum General Tech Discussion
    Last Post: 06-01-2010, 12:24 AM
