Thread: MAF low input
Results 1 to 10 of 10
  1. #1 MAF low input
    SE Level Member jakedidi's Avatar
    minnesota
    ive been getting the code, P0102 MAF low circuit input. ive went through 3 mafs trying to fix the problem (lifetime warranty part) and a new MAF connector. what else might it be??
  2. #2 Re: MAF low input
    Dec 2011
    Missouri
    I went thru the same type of deal on my '02 about a year ago. After the 2nd MAF sensor and still getting a code, I unplugged it, put some di-electric grease on the plug and put it back together and it never gave another ounce of trouble. Since you put a new connector on, I would guess a bad connection probably isnt your issue, but what I did to mine is something cheap and easy to try.
    The wierd part on my car though was when I was troubleshooting it, I swapped the MAF from my parent's Bonneville; and with an OEM sensor in my car I had no codes, and the code came back with the aftermarket sensor until I greased up the connection.
    2004 Grand Prix GTP Comp-G
    2002 Grand Prix GT-Sittin' in a junk yard somwhere-RIP
  3. #3 Re: MAF low input
    Charles City, IA
    uld just be cheap mafs.
    SMGPFC Two Nipple General
  4. #4 Re: MAF low input
    Charles City, IA
    could*
  5. #5 Re: MAF low input
    how did you connect the new pig tail to the harness for the maf?
    solider and shrink wrap work great, anything else is trash.
  6. #6 Re: MAF low input
    Possible there is a short in your wiring somewhere or you popped the fuse.
  7. #7 Re: MAF low input
    minnesota
    Quote Originally Posted by TheOtherNick View Post
    my MAF is a lifetime warranty one straight from GM.
    Quote Originally Posted by scottydoggs
    yep solder and shrink wrap.
    ill try the di-electric grease. ill let you guys know
  8. #8 Re: MAF low input
    Saratoga NY
    When my pcm lost its marbles it kept throwing the same code, then it started popping the fuse, then it bricked.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  9. #9 Re: MAF low input
    minnesota
    Quote Originally Posted by gmpowered View Post
    where is the fuse for the MAF?
  10. #10 Re: MAF low input
    Under hood it says IGN something
  1. Vss input help!!!
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-07-2010, 05:41 PM
  2. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  3. Looking to do HID's and need some input
    By J06GT in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2009, 06:27 PM
  4. Need some input
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 11-16-2009, 07:29 PM
  5. just want some input
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2008, 01:18 PM
