Thread: Core Support
Results 1 to 20 of 39
  1. #1 Core Support
    GT Level Member boothe's Avatar
    Troy, Mo
    Got into collision and need to replace my core support it got pushed in bent my radiator and fans... need any information on replacing the support
    Sent from my Motorola Electrify using Tapatalk
    Troy, Mo
    Links to information would be great
  3. #3 Re: Core Support
    St. Louis
    How bad is it? Could you just pull it back into shape or is it pretty boned? I've used a large slide hammer w/ a hook attachment in the past to pull them back straight. Also, what year car?
  4. #4 Re: Core Support
    St. Louis
    I'd check Rock Auto. Seems they run about $75 and up
  5. #5 Re: Core Support
    Ohio
    link dont work ford...idk why but you cant get a straight link from rockauto
    Troy, Mo
    Ill add pictures it pushed my fans almost against the headers id that gives any idea
  7. #7 Re: Core Support
    Ohio
    yeah ones listed for 73 and the other is 94. not bad price wise. or get one from the jy.
    Troy, Mo
    I tried pulling it out using a cherry picker it didnt work
  9. #9 Re: Core Support
    Ohio
    tyler id either order the one from rockauto or go to the junkyard. i dont see you paying more than 30 maybe.
    Troy, Mo
    Ita the radiator support on a 97
  11. #11 Re: Core Support
    Ohio
    every year 97-03 will be the same one.
  12. #12 Re: Core Support
    That's not an easy piece to replace. I think you need to ensure the frame/body is straight when you weld the new one in.
  13. #13 Re: Core Support
    St. Louis
    ^^This^^. You need to get measurements and be sure that everything is straight or the new support will NOT line back up again.
    Wrap a chain around it and use a tree to pull it out? You laugh, but I've seen it done. Maybe give CRC Auto Body down on Hwy79 a call and see what they'd charge.
    Let me guess, you ran it into one of those rusted out Dodge trucks running around Troy, lol... Heck, some of the cars I see out here in Old Monroe where I live I'm surprised they are even running the way they are wrecked.
  14. #14 Re: Core Support
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    like bill said. you really gotta make sure that the frame is straight. even if you get it looking straight ive seen cars that are just never the same again. sh!t just doesnt line up or whatever. sounds like its not too bad if the fans arent hitting the headers but that still doesnt mean anything. pictures would give better idea.
    if the frame is bent bad. honestly i dont think its worth all the work. better claiming it totaled and getting another gp
  15. #15 Re: Core Support
    Jan 2012
    Philadelphia
    under the hood X measurements to get an idea if the body is tweaked and also check door gaps and look for buckles in the body this is a uni body car so the force of impact can travel through the car
    Troy, Mo
    its not bent to bad i think for the most part the hood latch assembly pushed my radiator back
  17. #17 Re: Core Support
    Jan 2012
    Philadelphia
    but what i said is only really if you have to replace the rad support it doesn't look to bad i think you can straighten it. i know you could definitely straighten it if you had a frame rack
    Troy, Mo
    Quote Originally Posted by FordMan77 View Post
    Lol no it was a kid slammed on his brakes on wentzville pkwy
  19. #19 Re: Core Support
    Ohio
    the passenger fender-support brace bent out alittle. otherwise, doesnt look too bad.
  20. #20 Re: Core Support
    Jan 2012
    Philadelphia
    i see your support braces are bent for this fix to get the body to straightened out you will probably need a frame rack if you want your car to go back to pre-accident condition. for the rad support you will need to remove everything from the front of the engine fans, rad, support braces, engine mounts, bumper, fenders would be a good idea to take off to and every think in the front. Then you would get a drill with a mandrill bit this is designed to cut out your spot welds (do this after you have tried straightening this one) drill out your old spot welds (don't drill through both layers of metal you only need to drill through the rad support) and remove the rad support. Once you get your new rad support you wanna drill out holes in the same area as you drilled them out on the old spot welds (factory spot weld area) paint the rad support to match your car after you fit it in. Weld plug weld to the car and rad support using a MIG/GMAW after grinding the area down to bare metal (weld through primer might be good to use as well to avoid rust). Then grind down your welds to make them flush spray a primer or sealer over the spot welds after grinding and spray your color (you can also paint the rad support after its installed). You may need to use seam sealer in certain areas also. See how far you get with this and keep us updated on your repair. I will be more then happy to help you the best I can.
  1. Hood lift support? Help..
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-20-2011, 11:04 PM
  2. lumbar support
    By vincegpking in forum General Tech Discussion
    Last Post: 04-07-2011, 06:44 AM
  3. Needs some GPF support and votes!
    By Swash in forum Off Topic Discussion
    Last Post: 10-07-2010, 02:58 PM
  4. 2-support Mirrors
    By arc in forum 04+ Specifics
    Last Post: 02-08-2010, 02:42 PM
