Thread: Hood lift support? Help..
Results 1 to 18 of 18
  1. #1 Hood lift support? Help..
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    I've been looking at my local auto stores, and none of them say they have the hood struts for keeping the hood up. My car doesn't have any lift support under the hood, and its becoming a pain. If i ordered these, would it work? It says trunk in someplaces, then hood in others.
    Buy Strong Arm Lift Support E4119 at Advance Auto Parts
  2. #2 Re: Hood lift support? Help..
    PA
    Quote Originally Posted by GTLGDP View Post
    Your best bet is to take off your struts and measure them and compare them with the specifications post on the website. There are several different versions of the hood struts. Even better would be to take them off and take them into the store and compare them.
    2001 GSE
  3. #3 Re: Hood lift support? Help..
    St. Louis
    You can score them from Rock Auto. This is for an 03...
    MONROE Part # 901356 Max-Lift Gas Lift Support
    $13.71 each
  4. #4 Re: Hood lift support? Help..
    Oct 2011
    New Jersey
    Quote Originally Posted by FordMan77 View Post
    $13.71 each
    Link didn't work. I've looked on different websites too and i can't seem to find what i'm looking for. If anybody can find a link with something i can click on then order online, thatd be very helpful.
  5. #5 Re: Hood lift support? Help..
    you could just put vicegrips on them to hold it up. It's cheaper.
  6. #6 Re: Hood lift support? Help..
    Grand Rapids, MI
    ooor you could just go to a junkyard and get two for free that work awesome!
  7. #7 Re: Hood lift support? Help..
    PA
    Quote Originally Posted by brandonl2000 View Post
    oooor you could do what I suggested and go in a store and match up exactly what you need
    2001 GSE
  8. #8 Re: Hood lift support? Help..
    Grand Rapids, MI
    Free perfectly working struts>dishing out $
  9. #9 Re: Hood lift support? Help..
    PA
    Are you advocating stealing them from the junkyard?
    2001 GSE
  10. #10 Re: Hood lift support? Help..
    it's not stealing if you don't get caught lol
  11. #11 Re: Hood lift support? Help..
    Oct 2011
    New Jersey
    Lol i'm not stealing them from a junkyard -_-
  12. #12 Re: Hood lift support? Help..
    St. Louis
    www.rockauto.com
    This will get you to the catalog. Then just select your year, make and model and in the little search box type "hood support". There is a huge listing for them. They show the ones for the trunk and the hood so be sure to read the description.
    Here is the one that OReillys sells... | O'Reilly Auto Parts
    Then just take your old ones w/ you to make sure they are the proper length.
  13. #13 Re: Hood lift support? Help..
    Grand Rapids, MI
    www.rockauto.com
    RockAuto is awesome. There is a 5% discount you can get there. The code for October was 67305385588894. But they have not sent me the code for November yet.
  14. #14 Re: Hood lift support? Help..
    Oct 2011
    New Jersey
    www.rockauto.com
    I don't have the old ones cause they aren't on the car!
    But i see the Monroe Max-Lift Support, and the STRONGARM front lift support.
    Theyre both around $13, does it mater which one?
  15. #15 Re: Hood lift support? Help..
    St. Louis
    I wouldn't think so. As long as they are designed for the hood. Heck, someone could probably measure theirs and give you a good idea.
  16. #16 Re: Hood lift support? Help..
    Columbia, SC
    Strongarm #4119 are for the trunk that has a spoiler. I found the best prices for these at www.rockauto.com
  17. #17 Re: Hood lift support? Help..
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Your local dealer will be able to get these for you.
  18. #18 Re: Hood lift support? Help..
    Oct 2011
    New Jersey
    Haha this is old, i got them about 2 weeks ago
  1. Hood Lift Support
    By UCF04GPGTPCompG in forum General Tech Discussion
    Last Post: 12-30-2011, 12:07 PM
  2. Pontiac Lift Kit???
    By buckshot in forum Introductions/Noob Questions
    Last Post: 04-04-2011, 09:19 AM
  3. 02 Air Lift Suspension
    By Hawkins97 in forum Brakes/Suspension/Chassis
    Last Post: 07-25-2010, 11:13 PM
  4. Anyone here lift?
    By Panzer4 in forum Off Topic Discussion
    Last Post: 06-24-2010, 05:21 PM
  5. Got Lift?
    By Reptile in forum Off Topic Discussion
    Last Post: 11-24-2008, 03:04 AM
