Thread: Should I also get a hi-flow cat converter
Results 1 to 15 of 15
  1. #1 Should I also get a hi-flow cat converter
    Mar 2012
    Centerville, OH
    I recently ordered a set of headers from SSAC, and I wanted to know should I also get a hi-flow cat. converter as well. Will that be beneficial or is the stock cat. converter sufficient
  2. #2 Re: Should I also get a hi-flow cat converter
    Run catless?
  3. #3 Re: Should I also get a hi-flow cat converter
    Pennsylvania
    Never heard anything bad about the stock one. If you're close to 150,000 miles, I'd just get a new one or run catless, though.
  4. #4 Re: Should I also get a hi-flow cat converter
    Mar 2012
    Centerville, OH
    Run catless?
    Two question about running catless:
    1) Will that effect my emission test?
    2) If I run catless would I have to buy a pipe to replace the converter or should it all be the header set?
  5. #5 Re: Should I also get a hi-flow cat converter
    Answer to both...the headers come with everything to bolt up to a factory catback system...flange and all...but it comes with a race pipe, ala...no converter. But yeah, it all bolts up just fine with everything included.
    And unless you know someone that can pass it, then no, you will need a converter...
  6. #6 Re: Should I also get a hi-flow cat converter
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Catless is better.
    And no, it will fail emissions. If you get the O2 sensor faker from zzp, it will keep you from getting a trouble code. But if they use the sniffer, it will still fail.
    The evil LG8 still refuses to die.
    Mar 2012
    Centerville, OH
    Quote Originally Posted by Steel Armadillo View Post
    Catless is better.
    Would a tuned PCM help with that?
    I am here: http://tapatalk.com/map.php?kn1ir1
  8. #8 Re: Should I also get a hi-flow cat converter
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    Ohio doesn't do emissions testing anymore though, last i checked, so you would be fine running catless
    Mar 2012
    Centerville, OH
    I plan on moving within the next 1.5 years, so I was just concerned about any issues I would face.
    I am here: http://tapatalk.com/map.php?cymevn
  10. #10 Re: Should I also get a hi-flow cat converter
    Move to Missouri or Kansas.
    Honestly, no one gives two sh1ts here about anything.
    OR, buy a fake 3" cat from Frozen Boost and just bolt it in there...to add, what year is it? Because you can only run an o2 sim with '97-'00 cars...after that you need to actually run the rear o2, just remove the codes via the PCM.
    Mar 2012
    Centerville, OH
    It's a 2004
    I am here: http://tapatalk.com/map.php?xfp1ec
  12. #12 Re: Should I also get a hi-flow cat converter
    Actually, the simulator works on my 03...
  13. #13 Re: Should I also get a hi-flow cat converter
    Panama City Beach, FL
    PCM tune FTW. Nuke reporting for the secondary O2 and fly right thru your emissions test.
  14. #14 Re: Should I also get a hi-flow cat converter
    So the O2 sensor can be tuned out? Was it the EGR that couldn't be?
    Bunnell, FL
    Egr can be tuned out along with evap
    Android Fire
    I'm a Sex Offender
  1. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  2. more flow
    By BBluelandyacht in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 03:46 PM
  3. M90 flow?
    By SnowFlake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2011, 10:40 PM
  4. Is this a Hi-Flow Cat?
    By T0pwater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2011, 08:00 AM
  5. TDC flow
    Last Post: 05-16-2009, 10:52 PM
