Thread: Power Steering Leak - 2004 Grand Prix GT
Results 1 to 4 of 4
  1. #1 Power Steering Leak - 2004 Grand Prix GT
    Detroit
    Hi All,
    I have a 2004 Grand Prix GT, which has been leaking power steering fluid for.....longer than I'd like to publicly admit. Belle Tire told me I needed a new rack and pinion (no Magnasteer). Last weekend, I had it replaced. My mechanic told me that it would still whine for a while after the work was done, which it has. However, I noticed that I am also still leaking fluid. Could someone please give me some insight on what other components could be the culprit?
    Thanks,
    Thomas
  2. #2 Re: Power Steering Leak - 2004 Grand Prix GT
    all there really is, is the pump and the lines to the rack from the pump. clean it up, put car on ramps or jack stands, start it, and look for the leak. the boots on the ends of the rack if they are leaking the seals are bad.
    this was a new rack installed?
  3. #3 Re: Power Steering Leak - 2004 Grand Prix GT
    HUDSON
    SOmetimes it is both leaking (pump and rack), I just replaced both on my car at 165,000, althogh the rack was a reman. only 3 years old, it was leaking out both tie rod boots. The pump was leaking at the shaft seal. Also on the whine, if it was bleed properly, there should be no wine, wine means air in the fluid, and air in the fluid mean lack of lubrication. IF youre is still wining, lifts the front wheel off the ground, remove the fill cap and turn the steering wheel all the way one way, and back full the other way untill the wine is gone, then check your fluid to proper level. I will tell you my car had no wine after about 10 cycles, but the fluid was foamy, I let set a while and then repeated the procedure. I would not have driven the car if the pump was wining.
    Detroit
    Thanks for the replies.
    @scotty - I think it was refurbished. I got it from AutoZone.
    @quicksilver - I believe it was bled properly. The whine is gone after I put more fluid in, and I'm sure it's still leaking.
    It does look to be leaking less than before, so maybe the pump, lines, and/ or seals need to be replaced as well. I'll check it out. Thanks for the tips!
    I am here: http://tapatalk.com/map.php?ogrncg
  1. How-To: Replace the Power Steering Pump on a '03 Grand Prix
    By WalterWhite in forum How To Write-Ups/Tech Tips
    Last Post: 03-04-2013, 08:08 AM
  2. My 2004 grand prix power jumps in and out 3500+ rpm
    By jay1881 in forum General Grand Prix Discussion
    Last Post: 03-16-2012, 02:10 PM
  3. Power Steering Return Line for 2004-08 Grand Prix
    By ekt8750 in forum General Tech Discussion
    Last Post: 03-16-2012, 05:01 AM
  4. 2004 grand prix 3800 series 3 power-steering pump replacement
    By quickster in forum General Tech Discussion
    Last Post: 03-17-2011, 12:24 AM
  5. 1990 grand prix power steering?
    By barrylincon in forum General Tech Discussion
    Last Post: 09-03-2010, 06:05 PM
