Thread: 04 gtp injector.
Results 1 to 8 of 8
  1. #1 04 gtp injector.
    GT Level Member Toms04compg's Avatar
    Michigan
    I am changing flex plate but im having difficulty with the fuel rail injector process.... What has to come off and from where im sorry but i got no idea im really trying to save money per myself doing this. Thanks
  2. #2 Re: 04 gtp injector.
    Jan 1970
    Maquoketa, Iowa
    You shouldn't have to remove them for a flexplate...
  3. #3 Re: 04 gtp injector.
    Michigan
    What about the wire harness that goes to the fuel rail on top of charger?
  4. #4 Re: 04 gtp injector.
    Tom...
    Pull up sligntly on the green or blue piece, it'll move 2mm or so. Then push in on the tab and wiggle off the injector. The piece you move blocks the tab from being pushed and allowing the clip to release from the injector.
  5. #5 Re: 04 gtp injector.
    Michigan
    So basicall i will have a fuel rail with no injectors on and flop rail up when i pull motor?
  6. #6 Re: 04 gtp injector.
    That is a possibility. Also possible is to pick up the fuel line release tool (cheap at any parts store) and remove the line from the rail, then leave the rail on the motor.
    I read it originally that you needed to get the electrical connector off the injectors.
  7. #7 Re: 04 gtp injector.
    Michigan
    Yi think ill pick up the release tool .... Thanks man
  8. #8 Re: 04 gtp injector.
    Np...
  1. Broken injector tip
    By FordMan77 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2010, 10:55 AM
  2. Injector ?
    By CrazyGuy03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2010, 10:43 PM
