Thread: Vacumm line Question
Results 1 to 7 of 7
  1. #1 Vacumm line Question
    Wichita
    How acuratly must one follow the vacuum line diagram? Since installing fuel logs and a boost gauge my lines no longer run the way they should. I have the boost and fpr lines connected before the lim. Does that even matter?
    Fpr and map must see boost.
    The fpr raises and lowers fuel pressure so that the pressure across the injectors is always 58 psi (3.5 bar).
    This means the injectors will always have the same flow rate and offsets.
    This only applies if you have a fuel pump rewire.
    Without you'll need that fun shape gm came up with.
  3. #3 Re: Vacumm line Question
    Wichita
    And they both do. I was just curious. Thought maybe the map and fpr readings could be a bit off with the lines run a bit differently.
  4. #4 Re: Vacumm line Question
    Nope..vacuum is vacuum is vacuum and you don't need to worry about it as long as you grabbed from teh LIM
  5. #5 Re: Vacumm line Question
    Wichita
    ^^^that's all I needed to hear. Thx bill!
  6. #6 Re: Vacumm line Question
    Likely you don't live near me...so I can give you all the bad advice I want... lol
  7. #7 Re: Vacumm line Question
    Wichita
    ^^HA!
  1. Which Oil line is this?
    By Wakeboy1337 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-26-2011, 09:28 AM
  2. fuel line nut rusted to fuel line!!
    By Pepino in forum General Tech Discussion
    Last Post: 08-12-2010, 08:25 AM
  3. Brake line question
    By frankjc in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2010, 07:19 PM
  4. where does this vac line go?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 01:40 PM
  5. Fbody brake line question
    By minichopper6hp in forum Brakes/Suspension/Chassis
    Last Post: 05-09-2009, 05:00 PM
