Thread: EVAP canister purge valve vacuum line part number
Results 1 to 7 of 7
  1. #1 EVAP canister purge valve vacuum line part number
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    Does anyone know the part number for the vacuum line thatgoes from the TB to the purge valve on a 1999 GTP? I had kind of fixed it withsome Silicone vacuum line but it seems it's collapsing. Or do you know whatsize lines and fittings I would need to fix with universal stuff?
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  2. #2 Re: EVAP canister purge valve vacuum line part number
    Nov 2009
    Clinton, Ohio
    Think it may be part number 24506665.
    Anyone verify this?
  3. #3 Re: EVAP canister purge valve vacuum line part number
    IIRC I used 1/4" line from the evap to just near the TB. Then a 1/4" to 3/8" adapter and a small piece of 3/8" hose to connect to the tb
  4. #4 Re: EVAP canister purge valve vacuum line part number
    Nov 2009
    Clinton, Ohio
    Thanks Bill as always!
  5. #5 Re: EVAP canister purge valve vacuum line part number
    Anytime
  6. #6 Re: EVAP canister purge valve vacuum line part number
    Jul 2010
    Detroit
    Can the same part be used on a non-supercharged 3800? If not then what's the part number.
    Thanks in advance!
  7. #7 Re: EVAP canister purge valve vacuum line part number
    Again..I suggest regular black hose and the same approach. unless you have the super crappy double vacuum line. Then I use line and t into it for the fpr.
  1. transmission cooler line part number?
    By andremike in forum General Tech Discussion
    Last Post: 11-17-2014, 08:31 PM
  2. EVAP canister solenoid?
    By Pure2sin in forum General Tech Discussion
    Last Post: 07-19-2012, 11:33 PM
  3. Looking for Throttle Valve (TV, kickdown) cable Part number:10142050
    By 90blackgrandprix in forum Shops and Community Heroes
    Last Post: 02-15-2012, 12:21 PM
  4. L67 Vacuum Line Kit Part Numbers and Prices
    By MoarkatsINmuhtrailer in forum How To Write-Ups/Tech Tips
    Last Post: 01-16-2012, 01:19 PM
  5. Vacuum line parts number?
    By GAFF in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2011, 01:51 AM
