So i ended up buying VVME Bi-Xenon Headlights and Foglights. As i hooked them up the way i suppose to (well obviously not cause they arent working) but the lights turn on like normal but when i use my Hi-Beams nothing happens at all, no Hi-Beamsthe 2 ground wires from the H.i.D kit are connected to the battery and the one positive wire is to the battery too. Also, neither of my foglights will work because i think the car thinks that my Hi-Beams are always on (the Hi-Beams light on the dash and heads up display is always on). What did i do wrong? can anyone help? or did i just waste my money and should just go buy regular H.i.D's from VVME?
I originally put one ground here
And the other ground here, but now they are both connected to the battery.
The positive wire from the H.i.Ds wasnt big enough to fit over the battery bolt so i bought new connectors.
Extended the ground wires and put them to the battery
Positive wire
Few Random Pictures
