Thread: my car wont shift from park without pressing relese button
Results 1 to 11 of 11
  1. #1 my car wont shift from park without pressing relese button
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    I cant get it to shift from park what is that? and it's 15 outside
  2. #2 Re: my car wont **** from park without pressing relese button
    shift lock release maybe.
  3. #3 Re: my car wont **** from park without pressing relese button
    Dec 2011
    Grand Prairie, Tx
    Faulty neutral safety switch?
  4. #4 Re: my car wont **** from park without pressing relese button
    Sep 2011
    ohio!
    How much would it cost to get fixed and that's the only way I can get it to shift by pressing the release button
  5. #5 Re: my car wont **** from park without pressing relese button
    Dec 2011
    Grand Prairie, Tx
    Oriley's has an AC DELCO neutral safety switch for $58.99
    They also have a BWD for $89.99.
    I say go with the AC DELCO.
    Replacing it should be pretty easy. If you look on the drivers side towards the firewall you can see the switch sitting on top of the tranny. Should look like this..
    it's that black box looking thing on the transmission on the bottom left hand side of the pic..
  6. #6 Re: my car wont **** from park without pressing relese button
    Sep 2011
    ohio!
    Where and how is it installed?
  7. #7 Re: my car wont **** from park without pressing relese button
    Dec 2011
    Grand Prairie, Tx
    Look up in the pic I posted above. It's held in by 2 bolts, the shifter should clip right into it. All you do is loosen the 2 bolts and pop off the shifter and it comes right off.
  8. #8 Re: my car wont **** from park without pressing relese button
    Sep 2011
    ohio!
    And this is right inside the car?
  9. #9 Re: my car wont **** from park without pressing relese button
    Out West
    Referring to the title.
    Maybe it's constipated.
    Whine with your Cheese?
  10. #10 Re: my car wont **** from park without pressing relese button
    Dec 2011
    Grand Prairie, Tx
    Quote Originally Posted by 03limitedgtp View Post
    No, open your hood and look towards the firewall on the driver side in the engine bay. you'll see the transmission bolted up to the engine, just take a look around and you'll see it
  11. #11 Re: my car wont shift from park without pressing relese button
    Antioch, IL
    look under/near the brake cylinder.
    2009 Challenger SRT8
    Expert at being gay.
  1. Just became my most pressing issue!!
    By spider4 in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2011, 06:43 PM
  2. *SOLVED* Starts fine - will not idle or run by pressing pedal
    By cptnjarhead in forum General Tech Discussion
    Last Post: 10-10-2011, 06:58 AM
  3. Push button for park-lock solenoid in column??
    By BLOWN93LX in forum General Tech Discussion
    Last Post: 04-05-2011, 12:10 PM
  4. Stuck in park! Cant push shifter button!
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 04-05-2011, 09:23 AM
  5. Pressing the pulley off
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:01 PM
