Thread: *SOLVED* Starts fine - will not idle or run by pressing pedal
Results 1 to 10 of 10
Threaded View
  1. #1 *SOLVED* Starts fine - will not idle or run by pressing pedal
    Oct 2011
    Michigan
    Ok, 2000 GT 100,000+ miles.
    My wifes gt was idling strange past couple of days.
    rpms would go up and down but not consistently.
    Drove the car down state no problems, then drove back home no problems.
    parked car in drive way from wed to sat morning. my daughter got in it saturday morning and it will not stay running. the engine cranks great and starts, but will not stay runing. it dies after about 5 to 8 seconds. if you press on the gas it will rev up and down and the die.
    I replaced fuel filter and no change.
    could it be a key chip issue? my daughter bought some key covers and asked me if she could put them on and i said yes. she cut the rubber coding off the key and removed it, just to find out the covers she bought would not fit. could this be a security issue? i have unplugged battery for several hours and will try in the morning. the fuel pump kicks on every time and it starts fine. but will not stay running. any ideas?
    thanks in advance
  1. starts/ dies x10 then is fine
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  2. 2001 GP 3800 Wont Idle without gas pedal
    By BlaZiNRaIgN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2011, 11:31 PM
  3. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  4. Engine runs fine till temp starts to rise...
    By 97gpGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 11:22 AM
  5. Car takes two or three tries to start.. once warmed up starts fine.. Any info?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 03:42 PM
