Thread: Dyno Results
Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 261 to 280 of 295
  1. #261 Re: Dyno Results
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    You are assuming everybody ran race gas. I personally was running 94 octane pump gas with a bottle of NOS brand octane boost. I doubt if I was even 100 octane, more likely about 97-98. Also if I ran on a dynojet, as your runs are, power would have been 10-13% higher, plus mustang dyno correction is SAE, so add a bit more for STD. I am impressed with the ingenuity behind your swap, and the results are impressive, but some of your assumptions are a little off. People stopped using XP cams for the really high power builds 6-7 years ago when the XPZ came out. I think it's ****ty how some people are dumping on you but have to agree that some of it you bring on yourself. If you presented the results when you had them, instead of creating a thread 2 weeks ahead of time and asking for the drama, you would come across as more credible. Hopefully you take it to the track in the spring and actually prove what the setup can do.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  2. #262 Re: Dyno Results
    It was probably 94.5 if anything. And not because of the booster.
    Octane booster cannot affect octane significantly unless you have hardly any fuel in the tank at all.
    Also ultra 94 is a minimum of 94, its typically ~94.5
    FAQs — Questions, Answers, Octane, Gasoline Basics — Petro-Canada is octane?
  3. #263 Re: Dyno Results
    Banned
    CT
    Quote Originally Posted by SlowFiero View Post
    There's more than enough info out there to make a correlation in numbers to say that the TVS is about equal to heads/FullSizeIC/GenV.
    There isn't enough setups making 350whp on 93 without heads to say differently. Most IC/XP setups without heads on 93 octane are going to put down numbers that are significantly less than what the TVS made on 93.
  4. #264 Re: Dyno Results
    Feb 2009
    flintnasty MI
    Sure... but you are comparing these things and expecting us to get excited over a maximum of an 8% gain. mod for mod, dollar for dollar, gains from a turbo are in the 100% range, lol.
  5. #265 Re: Dyno Results
    Banned
    CT
    8% gain? I'm lost as to where you're getting this figure. The gain from GenV to TVS (299 to 350) was 17%... Add in some half ass ethanol and a setup that wasn't optimized yet and the gain was 25%.
    The gain from stock is about 100% (190 to 374)
  6. #266 Re: Dyno Results
    Feb 2009
    flintnasty MI
    Dont start...
    its not hard to find a VS cam gen5 no intercooler running E85 that makes 340whp(We will leave out the 93 octane xp/xpz/NIC cars that made 330+)... Just because you didnt doesnt mean you were not just stacking the deck in your favor. Your only "not mod" is heads and an intercooler... So there are plenty of people that have gotten well within 8% of your power level.
  7. #267 Re: Dyno Results
    Feb 2008
    Canada
    The NOS brand actually does something. Other ones are bs, add may be 0.5 octane. The NOS one typically allows me to run 4-5 degrees more timing on the same boost.
  8. #268 Re: Dyno Results
    Banned
    CT
    Dont start...
    Where are they? Running on dynapacks and dynocoms? lol
  9. #269 Re: Dyno Results
    Feb 2009
    flintnasty MI
    dynojet / mustang.
  10. #270 Re: Dyno Results
    Banned
    CT
    For every example of what you claim, I can find 10 that support my comparison.
  11. #271 Re: Dyno Results
    PA
    Quote Originally Posted by SnowFlake View Post
    So give us examples. I went off the information I had available. Until you show otherwise, its all just speculation. But with the information I had readily available, the costs are so similar for very similar power.
    2001 GSE
  12. #272 Re: Dyno Results
    Banned
    CT
    My example is the top 5 XP hp list. Take CKP out though because his and htownse's numbers are clearly bogus.
  13. #273 Re: Dyno Results
    PA
    Again....Proof of this?
    As I stated, I did my homework and showed how the builds are similar in power as well as cost. I felt I did a fair representation. Unless you show proof otherwise, I feel I was completely upfront and honest with the numbers.
    2001 GSE
  14. #274 Re: Dyno Results
    GT Level Member RegalGS98s's Avatar
    NJ
    Did you do any porting of the supercharger. I've never seen a TVS 1320 so I don't know what the inlet or outlet look like stock. Wonder what gains you would obtain if you didn't. I assume the Gen V's you've been comparing are ported.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  15. #275 Re: Dyno Results
    Banned
    CT
    The inlet on my genV was lightly ported... Other than that everything was stock.
  16. #276 Re: Dyno Results
    NJ
    So the TVS is untouched, any plans of porting it?
  17. #277 Re: Dyno Results
    porting isn't something that should really be done....
    polishing is where its at.
  18. #278 Re: Dyno Results
    Banned
    CT
    Don't wanna mess with a good thing... Eaton set this blower up well. I'm in no position to question them by porting it
  19. #279 Re: Dyno Results
    NJ
    Understood, as it could go the other way.
  20. #280 Re: Dyno Results
    Banned
    CT
    Yeah I'm not trying to gamble on a $1200 supercharger
  1. GTP Dyno Results!!!
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-17-2011, 11:25 PM
  2. ** Back from ZZP Trip - DYNO results **
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 04-27-2011, 11:28 PM
  3. sexy results :)
    Last Post: 05-12-2010, 08:48 PM
  4. results on the 07 ss
    By joe deleon in forum Track Sessions and Kills
    Last Post: 05-10-2009, 01:06 PM
