Thread: Dyno Results
Page 13 of 15 FirstFirst ... 31112131415 LastLast
Results 241 to 260 of 295
  1. #241 Re: Dyno Results
    Feb 2009
    flintnasty MI
    airflow.....
    You have to remember this "crap" I am posting is not just junk I learned from reading crap off the internet... I have been running E85 in 500+whp 3800s for 3 years now.
  2. #242 Re: Dyno Results
    Banned
    CT
    So you're contending that airflow is my limiting factor to 374whp and I will not make any more power by setting the car up for a better fuel?
  3. #243 Re: Dyno Results
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by SnowFlake View Post
    Have you discovered anything holding you back with the current blend of ethanol right now? When the blend changes what do you expect to happen?
  4. #244 Re: Dyno Results
    Banned
    CT
    Quote Originally Posted by FoSHO99 View Post
    Smaller pulley and more timing. I really should have been on the 2.6 with the open down pipe. Boost dropped from 14-15psi to 11-12 psi with the exhaust opened up. Non intercooled, the TVS should be run around 14psi and timing around 20* on ethanol. This is a lt of guesswork right now but that seemed to be where the car ran the best.
  5. #245 Re: Dyno Results
    Banned
    CT
    Quote Originally Posted by Zef_66 View Post
    Alright, so I wanted to break this down and see what it would cost to replicate this project. So here is the list of parts and prices that I came up with:
    Autolite Spark Plugs AL-104 US $12.00
    XPZ Cam Package COMP-XPZ 04-01-01338 with pushrods US $479.99
    Valve Spring Retainers 04-01-01157 Modified steel US $44.99
    Crow Cams Valve Springs CROW-4918-12 105 lb US $109.99
    Siemens Deka 60# Injectors 09-50-001100 Standard EV1 US $249.99
    Northstar Throttle Body Kit ZZ-NSTBK-5-MAF Used LQ4 MAF US $299.99
    ZZP Subtotal US $1,196.95
    Headers and Exhaust Work $200
    Supercharger $1500
    Adapter Plate $300
    Tuning $100
    Racetronix Fuel Pump $210
    Grand Total : $3510
    Now that is a lot in my opinion to get 350whp from stock. Granted some of those parts can be picked up used for cheaper. But if the point of the swap is reliability, then you don't want to go too cheap and too used. Not to mention I listed the TVS SC at $1500, which is way under new price just to please the masses. I didn't include any of the little stuff either, which we all knows adds up quickly. Like his alternator relocation, gaskets, fluids, bolts, etc, etc, etc. Right there you could probably add on another $500 easy. And a one time base tune for $100 that you can't really do any changes. Anyone looking to make the 375whp mark would probably want to get a tuner and do it themselves since E85 octane levels seem to vary so much.
    Overall, I think that is an honest look at what it would take cost wise to do this swap on a stock L67 engine (not L32 like the OP), and have it reliable.
    ORIGINAL: Zef_66
    XP Cam Package US $324.99
    Supercharger $1500
    Adapter Plate $300
    Tuning $100
    Grand Total : $3355
    Well... Let's just figure it out ourselves. First off, I have an XP, not an XPZ. So I fixed that.
    Cost for GenV to make similar power.
    ZZP Intercooler with modded fuel rails (the cheap ones) $1319.99
    ZZP Stage 3 heads (comes with springs) $1599.99
    ZZP Subtotal US $3807
    GenV blower + MPS and pullies - $500
    Tuning $100
    Grand Total: $4817... Nearly $1,500 more.
    I didn't include any of the little stuff either, which we all knows adds up quickly. Like gaskets, fluids, bolts, etc, etc, etc. Right there you could probably add on another $500 easy. And a one time base tune for $100 that you can't really do any changes. Anyone looking to make the 375whp mark would probably want to get a tuner and do it themselves since E85 octane levels seem to vary so much.
    Another great benefit of the TVS is that you don't need to go any deeper into the engine than the LIM, that's it! You also have the option of doing things like heads/IC ON TOP of doing the TVS for even more power.
    IMO, an honest comparison. Right Zef?
  6. #246 Re: Dyno Results
    Waukesha, WI
    do you any of you guys believe in using a local machine shops to do head porting for significantly less then zzpoops?
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
    Quote Originally Posted by redlinepontiac View Post
    I do and I know the shop to take them to in town, too.
  8. #248 Re: Dyno Results
    Jan 1970
    Maquoketa, Iowa
    But the fuel hasn't limited you thus far on the low blend or have you pushed it enough to tell?
  9. #249 Re: Dyno Results
    Waukesha, WI
    C&S is getting a set of my heads soon.
    edit because i dont want to make my own post: yup, them. in butler. i would definitely take something to them with zero worries.
    RayRay
    92 Turbo miata
    02 lexus is300
  10. #250 Re: Dyno Results
    Banned
    CT
    I would get knock on the street from time to time. It didn't knock on the dyno though... I really regret not bringing the 2.6. Might have been good for another 15-20whp with tuning.
  11. #251 Re: Dyno Results
    Lulz your cost chart of the heads cam IC gen5 setup look just as retarded compared to a Turbo setup that will stomp BOTH!
    Umm pretty much just the IC + Head cost in your breakdown makes going turbo a no brainer!
    "disclaimer hope I dont get an infraction or something lol"
    Option C turbo kit costs less than 3XXX.00
  12. #252 Re: Dyno Results
    Banned
    CT
    Ya know... I've been going over the dyno scans and there was some funky stuff happening. My ECT sensor kept popping in and out during the runs, sending commanded AFR all over the place. That and the dyno operator didn't take the car past 5700rpm on the last 2 runs. I told him 6500... I made 369whp at 5700rpm on the very last run. The 374 runs both had numbers 15whp under that at 5750 on the graph.
    I may have to go back...
  13. #253 Re: Dyno Results
    Waukesha, WI
    take some 110octane gas with you.....
    RayRay
    92 Turbo miata
    02 lexus is300
  14. #254 Re: Dyno Results
    PA
    Tuning $100
    Hmm, not really now that I have a second to look into it. Since E85 isn't available to everyone, and to make it a fair comparison, I looked at your base number of 350whp. Looking at the HP chart on CGP, there are several of people that made 350whp, or close to it on stock heads. So the ZZP S3 heads are not a necessity to make comparable HP to the TVS.
    So this is the price list that I came up with:
    X-P HOT Cam COMP-3312/3324-116+2-XP Modified Retainers US $344.99
    Intercooler 08-01-0061708-50-0063609-01-00534 Modified Fuel Rails Bosch pump US $1,319.99
    ZZP Subtotal US $2,336.95
    Tuning $100
    Grand Total: $3346
    Compared to the Updated TVS build:
    ZZP Subtotal US $1,016.96
    Supercharger $1500
    Adapter Plate $300
    Tuning $100
    Grand Total : $3326
    So right about even to get the same amount of power. That is a more honest comparison in my opinion.
    2001 GSE
  15. #255 Re: Dyno Results
    Banned
    CT
    Those guys on the high hp list are all on race gas or ethanol. My being on e60 only leveled the playing field.
  16. #256 Re: Dyno Results
    Kansas
    On top of all those prices, a given is for the tranny that is a hefty price in addition.
  17. #257 Re: Dyno Results
    PA
    Proof of that?
    2001 GSE
  18. #258 Re: Dyno Results
    Proof of that?
    I was kinda wondering that myself.
  19. #259 Re: Dyno Results
    well zzp claims hooper made 30 WHP more on his VS cam engine with S3 heads.... little do they mention that was on race gas.
    So 34x WHP on a VS? not really.
    In this sort of situation, you really want proof they were on pump, not vice versa.
  20. #260 Re: Dyno Results
    Banned
    CT
    Proof of that?
    Type their name into the search bar under author and type "Dyno" into the search field. Cross reference their numbers with the corresponding thread they created. I haven't found one person with relevant numbers who was on 93 octane.
  1. GTP Dyno Results!!!
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-17-2011, 11:25 PM
  2. ** Back from ZZP Trip - DYNO results **
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 04-27-2011, 11:28 PM
  3. sexy results :)
    Last Post: 05-12-2010, 08:48 PM
  4. results on the 07 ss
    By joe deleon in forum Track Sessions and Kills
    Last Post: 05-10-2009, 01:06 PM
