Thread: Fluctuating RPMs while driving/idling
Results 1 to 20 of 24
  1. #1 Fluctuating RPMs while driving/idling
    SE Level Member matthew911's Avatar
    Feb 2010
    '00 GP GT. It's still a minor problem so hopefully I can get this fixed before it gets worse. I've noticed a small fluctuation in the RPMs while the car is either in drive or idling. I'd say it's probably no more than a few hundred RPMs, but if I'm cruising down the highway it's enough to be noticeable. It doesn't happen all the time, just here and there. Seems to do it more than it used to though. Happens with or without cruise control engaged. As far as I can tell it's only a problem when I'm going a constant speed. Only increases RPMs, doesn't decrease.
    I'm on a tight budget so I'd like to start with the cheapest possibility, lol. I've read the TPS might be the cause, but that seems to start at around $40 for a new one. Could be worse I guess.
  2. #2 Re: Fluctuating RPMs while driving/idling
    new britain, ct
    is it running any codes? sounds like a slight misfire which is usually caused by spark plugs/wires.
    07 Black GXP.
  3. #3 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    SES light isn't on. Would it still pick up any codes? I recently replaced the plugs, but this started before that and hasn't gone away since then.
  4. #4 Re: Fluctuating RPMs while driving/idling
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    mass airflow sensor or vacuum line somewhere possibly?
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    I hope it's not the MAF since I replaced it once already, but it was from a junkyard, so who knows. How easy is it to spot a vacuum line?
    Edit: I do have an extra MAF floating around somewhere. Wouldn't hurt to give it a try I guess.
  6. #6 Re: Fluctuating RPMs while driving/idling
    brunswick
    carb cleaner... crank ya car spray it and listen for an change
    edit... spray it around ya vacuum lines and intake area's
  7. #7 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Thanks for the help. Hopefully I can figure this out.
  8. #8 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Update. Didn't see anything around the vacuum lines. The RPM issue is definitely noticeable on the highway. Feels a little jerky sometimes. It has also stalled twice in the last week or so while waiting at a red light. Any other ideas?
  9. #9 Re: Fluctuating RPMs while driving/idling
    Jun 2011
    Detroit, MI
    air filter? lol
    if not that.. then it sounds like a maf problem
    iLoveSpade
  10. #10 Re: Fluctuating RPMs while driving/idling
    Clogged Cat OR if you think its the MAF, unplug it and drive it around...if it drives fine, then the MAF is bad.
    And joe, quit trying to diagnose crap...air filter...wtf?
    Local has that issue on his '99 GTP. Replaced plugs, wires, MAF, vac lines, fluids/filters, etc.
    Ended up being a clogged converter.
    You can buy a Magnaflow High Flow unit off of EBay for like 50~ bucks...take it to an exhaust shop and have it welded in, and have the U-Bend taken out of the exhaust right after the cat while your there.
  11. #11 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Excellent, thank you. I don't think it's the MAF. I replaced it within the last year, but I also had an extra one sitting in my garage that I swapped out a couple days ago. Didn't fix the problem. I suppose I could still unplug it for a while and see what happens. Seems like two bad MAFs would be unlikely. Parden my stupidity, but what's the advantage of taking out the u-bend?
    Edit: I put in my own air intake recently, and this problem existed before I did that, so that's definitely not it...in case there was any doubt...
  12. #12 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Sorry, one more quick question. What size converter am I looking for? 2.5"? I'm very broke and I need to keep this under $100 if possible.
  13. #13 Re: Fluctuating RPMs while driving/idling
    GT Level Member thegipper's Avatar
    grafton, wi
    Why don't you take out your 02 sensor before the cat so you can be sure that the CAT is the problem. The exhaust gases will be able to escape from the hole. If it runs better, then you KNOW its a bad cat. You said you were on a tight budget. Might as well make sure that's the problem before you start ordering parts.
    Good luck !
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  14. #14 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    I'd like to pose a new idea. There's something else that's a little off that I forgot to mention. Sometimes when I slow down for a light or stop sign, and then accelerate, it shifts very hard. I've done some research and that combined with the surging problem I'm having could be the TCC solenoid. It might be locking up and not releasing properly. Thoughts?
    If that's a possible cause I might be better off trying to replace the TPS first, as I've read that can also cause the TCC to lock up.
  15. #15 Re: Fluctuating RPMs while driving/idling
    GTX Level Member bronzemist02's Avatar
    Canada
    my car had the same shifting problem. I had the solenoid replaced and it fixed it. My truck has the fluctuating problem. I cleaned my maf and it seemed to help a bit. It is still fluctuating on the highway though. I'm thinking maybe my torque converter isn't working right. The truck is shifting into overdrive at about 60 km an hour under light acceleration. I'm getting the trans fluid and filter replaced soon.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  16. #16 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Quote Originally Posted by bronzemist02 View Post
    I'd like to have my trans fluid and filter replaced also, but it's fairly expensive to have done (at least on my tiny salary), and I'm not sure how easily I'd be able to do it. I've been pretty lucky with this car and haven't had to replace very much in the 2 years I've had it.
  17. #17 Re: Fluctuating RPMs while driving/idling
    Jun 2011
    Detroit, MI
    It was kind of a joke... but if the air filter is clogged then there will be problems..
    iLoveSpade
  18. #18 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Ok, another update. Car stalled on the way home tonight. Didn't want to start again. Finally got it going, took off, and I heard the distinct sound of metal hitting the road. Went back and picked up the piece. Can anyone tell me what it is? Lol...I'm assuming part of the exhaust, but I don't really know for sure. Too dark and freezing outside for me to get under and look.
  19. #19 Re: Fluctuating RPMs while driving/idling
    Jun 2011
    Detroit, MI
    Does your exhaust sound different? I don't recognize that, it might just be road debris.
    iLoveSpade
  20. #20 Re: Fluctuating RPMs while driving/idling
    Feb 2010
    Doesn't sound any different. I know it wasn't in the road already, it's pretty big. Would have been easy to see. Someone else here mentioned it might be a heat shield. Doesn't affect how the car runs so it's not too big of a deal. I'm a lot more concerned about the surging RPMs and stalling.
  1. rpms bouncing while driving between 2nd and 3rd
    By RyanL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2012, 02:57 AM
  2. xp cam fluctuating rpm
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2011, 12:14 AM
  3. Fluctuating RPMs 05 GP
    By NegativeOne13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-31-2011, 01:19 PM
  4. Jumping/Fluctuating RPMs
    By birdgm in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2010, 12:46 PM
  5. Badly Fluctuating RPM's
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 08:07 AM
