Thread: The issues just keep rolling in.....
Results 1 to 15 of 15
  1. #1 The issues just keep rolling in.....
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    All i can do is laugh at how many issues are starting to occur on the car. Get one thing fixed and three more pop up. I really should take a grenade to it. Anyway this might not be much of an issue but who knows. The car just had an oil change and this is right after the upper/lower gasket replacement. Ive been driving past two days no real issue however last night i got caught in stop and go traffic at the tunnel,so i was braking alot. The oil indicater light kept flickering on then off. Has never done this before. I read in the manual that it may flicker sometimes from hard stops however i wasnt really hitting the brakes hard just stopping quite often. After we got through the traffic no problems and none today. However the other thing that is occuring is the DIC is usually set on fuel range but now when i start the car it is always on oil life percentage and it always flashes a LOW. Ive checked the oil and it shows full. Ive also checked around the gasket repair work for any leaks and none. I had read in the manual that the oil lamp will come on if you are not getting proper oil compression however as i said the oil lamp stopped flickering after the stop and go traffic.
  2. #2 Re: The issues just keep rolling in.....
    get a oil pressure gauge, that way you always know whats up.
  3. #3 Re: The issues just keep rolling in.....
    Nov 2011
    portsmouth,virginia
    Ok scotty. Where would i hook up this gauge?
  4. #4 Re: The issues just keep rolling in.....
    Hi, My name is Nick.
    I've blown up like 97 motors.
    When you beat me on that number...then you can complain.
    Thanks
  5. #5 Re: The issues just keep rolling in.....
    Feb 2010
    TN
    spider it could just be a bad senor and no real problem I feel for ya guy went nuts looking for a problem with my Grand prix that was caused by the dealer who he brought it in for a recall took about 6-8 months to get to the root of the problem and about $1,000.00 worth of parts I did not need
  6. #6 Re: The issues just keep rolling in.....
    by the oil filter there is a sensor, remove it and screw the pressure gauge into the hole there. you can also use a T fitting and hook both up if you like.
  7. #7 Re: The issues just keep rolling in.....
    Nov 2011
    portsmouth,virginia
    Thanks logan. Yeah so far ive spent about $1500 for various parts and repairs. Most things overall dont bother me and once i find out from others on here with the same issues and solutions it makes me feel better. Although seems like since ive had the upper/lower gaskets done ive got this annoying rattle. But you cant hear the rattle from the engine bay only from inside the car.
  8. #8 Re: The issues just keep rolling in.....
    heat shields loose?
  9. #9 Re: The issues just keep rolling in.....
    Feb 2010
    TN
    thats my guess scotty
  10. #10 Re: The issues just keep rolling in.....
    Which oil light flickered, the low oil light or the oil pressure light?
    yeah..that's right.. I just beat down ScottydaDoggger lol
  11. #11 Re: The issues just keep rolling in.....
    Wichita
    Your not having issues wih your GP until you've replaced the engine, transmission, both bumpers and everything in between, haha.
  12. #12 Re: The issues just keep rolling in.....
    Nov 2011
    portsmouth,virginia
    Bill the Oil pressure light is the one coming on. I checked oil level anyway and it is full (remember i just had it changed after that upper/lower intake gasket replacement). The oil pressure lamp is doing more of a flicker and is not doing it when the car is moving or even if it is in park or neutral). Right now the light only starts to flicker after the car has been on and running for about and hour and i have the car in drive and foot on brake. As soon as i start driving( or in this case today hopped on the interstate and drove for 15 minutes) no light at all. The other thing i did when the light was flickering because i was in stop and go traffic, I pulled into a store cut car off for like 5 minutes then cut it back on put it in the drive gear with foot on brake(the scenerio thats been giving me the flickering)and got no light after running the car for 5 minutes.
  13. #13 Re: The issues just keep rolling in.....
    Crap...have the oil pressure tested. Test it warm and in gear if possible.
  14. #14 Re: The issues just keep rolling in.....
    hey bill that's what i said originally, who beating who up now?
  15. #15 Re: The issues just keep rolling in.....
    I'll smack you around when you read your pm's finally..lol
  1. Rolling in the Deep LIL WAYNE
    By benner in forum Off Topic Discussion
    Last Post: 09-19-2011, 09:39 PM
  2. help !!!....smoke came rolling inside etc
    By jraypickett in forum General Tech Discussion
    Last Post: 06-29-2010, 05:32 PM
  3. Rolling Your Rear Fenders Option #1 [*]
    By TommyGloves in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:52 PM
  4. Rolling Rear Fenders Option #2 [*]
    By VinnieGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:51 PM
  5. fender rolling i suck...ftl
    Last Post: 06-05-2009, 03:30 PM
