Thread: Rocker Panel Slip on replacements?
Results 1 to 10 of 10
  1. #1 Rocker Panel Slip on replacements?
    Florida
    Anyone know anything about these from RockAuto?
    SHERMAN Part # CCC84404R
    Right; ROCKER PANEL SLIP-ON STYLE; Right; Sedan; 4 door
    SHERMAN Part # CCC84404L
    Left; ROCKER PANEL SLIP-ON STYLE; Left; Sedan; 4 door
    I'm replacing the passenger doors and the fender and when I took off the rocker panel molding, some of the metal under the bracket crumpled like a saltine cracker. I suppose I need to replace the rocker panels, so I was looking over at rockauto's site and I saw these, wondered if anyone knew anything about them.
  2. #2 Re: Rocker Panel Slip on replacements?
    Nothing about slip on and metal crumbling sounds legit Ebay also sells the weld on ones. About 70 bucks per side IIRC
  3. #3 Re: Rocker Panel Slip on replacements?
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    one proablem with slip on. the metal is still rusting under them. you need to netralize all rust and at that point why not just weld on new rockers?
    make sure the inner rockers are still there though before you get to far into it. the inner rockers being gone is what doomed my GTX as it started folding in on it's self and became the banana prix
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
  4. #4 Re: Rocker Panel Slip on replacements?
    Florida
    You're saying that slip on rockers from rockauto don't sound legit? Hm. I thought they were a pretty reputable company.
  5. #5 Re: Rocker Panel Slip on replacements?
    Feb 2010
    my house
    rock auto just stocks the parts they do not make them.
    slip on is just a bad idea
  6. #6 Re: Rocker Panel Slip on replacements?
    Exactly why I've been giving Spartan hell about painting his car with the rocker moulding on! Even with all the money he's got in that car if its not done right whats the point? I seen his wet paint pics and the lower rocker trim is off but the trim is still on the bottom of the door. Now why half way do a job like that?
    Maybe I'm too fussy which is exactly why my own sh1t never gets done either!
  7. #7 Re: Rocker Panel Slip on replacements?
    Feb 2010
    my house
    here is my old GTX (ignore the GTP badges it was in a front end accident and converted back into a GTP when a SLP hood could not be found)
    the plastic moulding literlay just fell off the car and the inner rocker the actualy support of the car was like a cracker i could grab the carpet form under the car and pull on it. the driver side was just as bad
    here is how it looed just 3 months before
  8. #8 Re: Rocker Panel Slip on replacements?
    SE Level Member johnniep's Avatar
    nova scotia
    i had mine done 4 months ago......had them cut off and replaced them for 70.00 a set.....about 300.00 labor.....chances are they're crumbly by the floor....new ones will give it strength...i've seen a few that actually weakened the car to the point some doors will stick
  9. #9 Re: Rocker Panel Slip on replacements?
    Feb 2010
    my house
    yup my black car bowed in the middle and i could no longer shut the doors
  10. #10 Re: Rocker Panel Slip on replacements?
    I keep going back and forth with weather or not to fix my rockers or just find one in better shape. I'm not sure what to do now :S
  1. anyone know there to buy new rocker panel moldings
    By Doug 97 gtp in forum Visual/Body Modifications
    Last Post: 01-06-2012, 03:18 PM
  2. 6x9 replacements
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2011, 10:42 PM
  3. OEM replacements?
    By BSmout in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2009, 03:41 PM
  4. rocker panel replacement??help??
    By brian91z34 in forum General Tech Discussion
    Last Post: 02-23-2009, 09:23 PM
