Thread: help !!!....smoke came rolling inside etc
Results 1 to 3 of 3
  1. #1 help !!!....smoke came rolling inside etc
    Jun 2010
    IA
    hey all..I picked up this 97' grand prix SE a few weeks ago...a couple of nights ago I left the passenger window down @ night and it rained pretty good.....so the door panel inside was wet and the carpet, and the seat kind of...
    yesterday while on the highway ...instantly smoke (burn smell ) came rolling through the passengers side interior vents/glove box/under glove box...I had my 4 year old son and immediately pulled over and got out, and got him out..popped the hood and nothing under there.....and within a minute of the car sitting there it was gone.....i started it and drove it 20 miles to work later and it acted like it never happened ( no high temp, normal idle, drive etc..).....then when I got off @ midnight last night..I came out and started it, and my speedometer dash lights wouldn't come on, and neither would my headlight/daylight lamps/corner lamps.....so I dont know what happened or what it could be ?.....
    someone told me possibly water got in the heater core and burned it up, and I should disconnect it?.
    i checked the fuses for the main headlights ( 60 amp ) under the hood in the fuse box and those are fine...any suggestions on whats going on or what to do/look for ?
  2. #2 Re: help !!!....smoke came rolling inside etc
    Most likely something behind the dash shorted out from the water. Usually a smoke like you mention is caused by wires heating up and melting together.
  3. #3 Re: help !!!....smoke came rolling inside etc
    SE Level Member disblile's Avatar
    Jun 2010
    Ohio
    ok, i would check in your under hood "relay center" pull up the box to check the wiring underneath. i had a 1992 at one point in time that did the same thing and it turned out some wires touched under neath the relay box and melted a lot more wires underneath it. messed up all my lights inside as well as my cooling fans and a/c
  1. So I found out why my rear window wasnt rolling down...
    By daniel981 in forum General Tech Discussion
    Last Post: 06-04-2011, 09:22 PM
  2. Rolling back while in drive on hills?
    By shawnz90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 09:57 PM
  3. Rolling Your Rear Fenders Option #1 [*]
    By TommyGloves in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:52 PM
  4. Rolling Rear Fenders Option #2 [*]
    By VinnieGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:51 PM
  5. fender rolling i suck...ftl
    Last Post: 06-05-2009, 03:30 PM
