Thread: Ugh.... Coolant Elbows................................
Results 1 to 8 of 8
  1. #1 Ugh.... Coolant Elbows................................
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    I know the elbow itself is not cracked. So its where it seals up. Would using some copper RTV around the elbow be a decent fix till it warms up? Or am I screwed again.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Ugh.... Coolant Elbows................................
    those are easy to replace, just get new ones and lube them up when you put them in so the seal dont rip.
  3. #3 Re: Ugh.... Coolant Elbows................................
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    Its gonna be close it 40 all week in our area. Better off replacing it instead of fighting with the leaks.
  4. #4 Re: Ugh.... Coolant Elbows................................
    Oct 2008
    IL
    Quote Originally Posted by bps02gtp View Post
    Sweet maybe Ill just tackle it this week then the ones I got are 6 months old. Its pretty much my own dumbass fault..... I was trying to fix a vacum leak at the T right by the passanger side elbow so I used some heat shrink for the time being...... Well the 1,000 degree heat gun I used was probably a dumb idea. You learn as you go I guess. Not sure if that was the cause tho.
  5. #5 Re: Ugh.... Coolant Elbows................................
    Nov 2010
    Illinois
    I would have to see it to know the cause. Good thing they're cheap
  6. #6 Re: Ugh.... Coolant Elbows................................
    Oct 2008
    IL
    Oh I already have an extra set so thats not the issue. Fixing sumthing that was just fixed 6 months ago is what pisses me off
  7. #7 Re: Ugh.... Coolant Elbows................................
    Minnesota
    Some people have had back luck with the Dorman elbows and say the GM ones are better. If the new ones leak again I might check into the GM ones.
    Make sure you lube the o-rings and double duty would be to put a bead of gray not copper RTV around the the plastic part of the elbow before you install it.
  8. #8 Re: Ugh.... Coolant Elbows................................
    Oct 2008
    IL
    Quote Originally Posted by Pure2sin View Post
    See these only failed because I had the heat gun to close to them trying to heatshrink around that vacuum fitting I was having an issue with. So pretty much Im a dumbass
  1. coolant elbows. Yes, coolant elbows
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2012, 04:46 PM
  2. Coolant Elbows
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 05:51 PM
  3. How hard is it to do coolant elbows?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2011, 06:25 PM
  4. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  5. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
