Thread: Ugh.... Coolant Elbows................................
Results 1 to 8 of 8
  1. #1 Re: Ugh.... Coolant Elbows................................
    Minnesota
    Some people have had back luck with the Dorman elbows and say the GM ones are better. If the new ones leak again I might check into the GM ones.
    Make sure you lube the o-rings and double duty would be to put a bead of gray not copper RTV around the the plastic part of the elbow before you install it.
  2. #2 Re: Ugh.... Coolant Elbows................................
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Quote Originally Posted by Pure2sin View Post
    See these only failed because I had the heat gun to close to them trying to heatshrink around that vacuum fitting I was having an issue with. So pretty much Im a dumbass
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  1. coolant elbows. Yes, coolant elbows
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2012, 04:46 PM
  2. Coolant Elbows
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 05:51 PM
  3. How hard is it to do coolant elbows?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2011, 06:25 PM
  4. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  5. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
