Thread: Coolant Elbows
Results 1 to 9 of 9
  1. #1 Coolant Elbows
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Well, as always, I used the Search button before making a new thread. Problem is, all the threads I read about Coolant Elbows are for the most part, conflicting.
    So, here it is...the question..
    Do you have to remove the Lower Intake in order to replace the coolant elbows?
    Also, a couple threads I read said the elbows can be found in the "Help Section" We have that section in the Canadian Tire stores here up in Canada, but does anyone know the actual part numbers to look for IN the help section? There's a few PVC elbows in that section.
    The upper elbow on the 97 Grandprix I just bought it leaking and needs replaced. From what I read disconnect the battery, remove alternator, couple bolts that hold that bracket on...remove the bracket..remove the broken pieces..clean up with emery, lube o-rings, reassemble? Im going to do the valve cover gaskets at the same time.
    Thanks for looking,
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  2. #2 Re: Coolant Elbows
    Lansing, Michigan
    Try this: How To Replace GM 3800 Heater Hose Fittings: 2004 Pontiac Grand Prix - YouTube
    I know this is a 2004, but yours should be the same.
    Hope this Helps..........
  3. #3 Re: Coolant Elbows
    Ontario, Canada
    Awesome. Thanks.
  4. #4 Re: Coolant Elbows
    Ontario, Canada
    So...replaced the Coolant ELBOW tonight....
    Thats right, Elbow...as in singular... The pipe that goes into the water pump (so the lower one) was a cast pipe to the tensioner casting..there was only 1 plastic elbow, and it was broken on both ends.
    Anyone else only have 1 elbow?
    I took the o-ring off the coolant elbow and installed it on the cast in pipe.
    Jay
  5. #5 Re: Coolant Elbows
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    i thought it was only the 97 that had the cast elbow with the assembly.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  6. #6 Re: Coolant Elbows
    95-99 Bonneville (with S2 motor)
    95-99 PA (with S2 motor)
    95-99 Riv (with S2 motor)
    95-99 LeSlopper (with S2 motor)
    97-98 GP/Regal
    98 Trigue/Monte (maybe Lumina) (with L36)
    That's most of them. Mighta left out one
  7. #7 Re: Coolant Elbows
    Ontario, Canada
    Well, its fixed...the sone elbow was deff leaking. Not any more. Bleeding the cooling system is a PITA on these cars...I thought Toyota Camrys with the old 2.2L 4 lunger was bad... The cooling system still has air in it, heater core tells me so...gurgle gurgle. I have fire practice tonight, but im gonna try gacking up the drivers side of the car and open the bleeded once more before I leave work.
    Also, the rad must be right stuffed full of Dexcool Soup at the bottom by the drain...it drains very slowly, and sometimes stops....give the drain cock a wiggle and it will flow again. Took me a while to figure out its a quarter twist and pull (or in my case pry, grunt and coax) out to the open position. Is there any way to completely remove the drain cock from the radiator so I can power flush the rad with a garden hose? Im going to have to do another flush here shortly anyways, because I know for a fact I did not get all the dexcool out. The previous owner worked as a parts jockey at a GM Dealer, so it still had DC in it. He had the dealership do all the maintenance.
    Jay
  8. #8 Re: Coolant Elbows
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    You can mess with the little bleed valve all day it won't get the air out of the heater core. When the car is cooled jack the front up and let it run with the radiator cap off (old school way). Keep your coolant handy and fill it as it lowers it will need filled when your thermo opens up. After you stop seeing the air bubbles put your cap back on and it should be better. Then bleed off the nipple to get any extra air out.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  9. #9 Re: Coolant Elbows
    Ontario, Canada
    Thats the way I did it last night. Had the front end jacked way up to get it higher than the heater core...same thing we did with the 2.2 Camry's when I worked at Toyota.
    I'll have to do it again I guess.
    Jay
  1. How to change coolant elbows
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 02-20-2017, 07:51 PM
  2. How hard is it to do coolant elbows?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-02-2011, 06:25 PM
  3. Need to replace coolant elbows
    By Posty101 in forum Engine
    Last Post: 06-02-2011, 02:22 PM
  4. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  5. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
