Thread: Blown fuses...need a little help
Results 1 to 4 of 4
  1. #1 Blown fuses...need a little help
    GTX Level Member nikkigpgt00's Avatar
    MI
    Is there a fuse for the cigarette lighter and the charging spot near the passenger side floor? Neither one of them work and I need at least one for my car charger. If it is a fuse anyone know which one it takes?
    Also, I need to know the size fuse for the rear defrost. Can't find it in the book???
  2. #2 Re: Blown fuses...need a little help
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    There is a fuse for the cig lighter. Check the fuses in the glove box. Rear defrost should be labeled in the same area and will tell which one it is when u pull the access door off.
  3. #3 Re: Blown fuses...need a little help
    MI
    Thx! I found em both. Im missing the access door so I'm not sure if the fuse I put in the rear defog is correct. I changed it a few months ago and it was missing and then the 20 I put in blew so I tried a 25.
  4. #4 Re: Blown fuses...need a little help
    Nov 2010
    Illinois
    Ah. Well glad u fixed them. If I would've known u didn't have the access door I would've helped u out a little more lol
  1. Replies: 1
    Last Post: 01-17-2012, 09:24 PM
  2. Blowing Air Conditioning Fuses
    By ls1camino in forum General Tech Discussion
    Last Post: 07-25-2011, 07:47 AM
  3. Question bout 88 GP fuses
    By MarkUSAF in forum General Tech Discussion
    Last Post: 07-20-2011, 12:20 PM
  4. RAP and Power Drop fuses
    By Warbeaver in forum Audio, Security & Visual Electronics
    Last Post: 05-17-2010, 08:53 PM
  5. HID Fogs keep blowing fuses. Wtf?
    By TheDesertFox in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2009, 01:11 PM
